Head-Fi's Sponsors
(Premier Sponsors bolded) |
Can Jam '09
(2009
International
Head-Fi Meet)
Impressions,
Reviews, Photos |
Can
Jam '09 graphic
courtesy of Edwood
Click on the links below
for Can Jam '09 photos,
impressions and reviews:
blubliss
1,
2,
3
dallan
1,
2,
3,
4
santacore
1,
2
nhat_thanh
1, 2
vpivinylspinner
1,
2,
3
amb
1
augustwest
1
eaglejo
1
johnsonad
1
shellylh
1
Jon L
1,
2,
3,
4
Germancub
1
zippy2001
1
IPodPJ
1
bhd812
1
Edwood
1,
2
abellaw
1,
2
minidiscs
1
atothex
1
HighLife
1
achristilaw
1
SiBurning
1,
2,
3,
4
SiBurning
5,
6,
7
LFF
1
Iron_Dreamer
1
doping panda
1
morphsci
1
ironbut
1
shaizada
1
jasper994
1,
2
jp11801
1
Uncle Erik
1
drubrew
1
(More impressions/photos
still being added.)
Head-Fi Blogs
and Facebook |
Head-Fi's Sponsors
| Computer Audio Discussion of computers as source components, sound cards, USB DACs, media servers, etc. |
03-20-2007, 02:57 PM
100+ Head-Fi'er
Before
Testing chain: External loopback (line-out - line-in)
Sampling mode: 24-bit, 96 kHz
Summary
Frequency response (from 40 Hz to 15 kHz), dB: +0.01, -0.09 Excellent
Noise level, dB (A): -112.8 Excellent
Dynamic range, dB (A): 112.5 Excellent
THD, %: 0.0006 Excellent
IMD + Noise, %: 0.0012 Excellent
Stereo crosstalk, dB: -110.5 Excellent
IMD at 10 kHz, %: 0.0012 Excellent
General performance: Excellent
After mod, change opamp, ERS paper, new capacitor
Summary
Noise level, dB (A): -113.1 Excellent
Dynamic range, dB (A): 112.9 Excellent
IMD + Noise, %: 0.0011 Excellent
Stereo crosstalk, dB: -110.9 Excellent
__________________
Take responsibilities for your actions.
Feedback
03-20-2007, 04:29 PM
Head-Fi'er
Originally Posted by Liver
Before
Summary
Summary
very slight differences in spec, what about you opinion on audible?
__________________
Foobar > Partly Modded X-fi > HD595
.flac .mp3 320k
03-20-2007, 05:04 PM
Head-Fi'er
Before
Summary
Summary
Maybe this is the limit of the x-fi recording capabilities ?
03-20-2007, 05:54 PM
1000+ Head-Fi'er
Originally Posted by Gilly
i tried to get them direct from national semiconductor, they wanted about $19.50 postage, i might as well order them from here, there about £4 or summat
I think that they (National) have increased the price due to high demand. I got the order confirmation March 13, and payed $9 for 3 samples and delivery to Sweden.
03-20-2007, 06:00 PM
100+ Head-Fi'er
hmm- what card was it that you took those specs? Did you change the recording op-amp as well, or just the output opamp?
__________________
Team AKG
Team College
Dorm Rig: X-Fi Elite Pro(modded) bitperfect out to--> DIY Maxed Pimeta w/ TREAD/ SOHA-->AKG K501(recabled)
Onkyo c390(thanks asr!)/Modded Sony SCD-595-->5687 Tube Preamp --> Firstwatt F2 clone-->Tekton Design 4.1's
Portable: AlienDAC--> Cmoy-->ETY ER4-S
03-20-2007, 06:27 PM
100+ Head-Fi'er
I'm going to mod mine. But going easy - just changing the opamps for the LM4562 and nothing else. It's my first time at soldering, but I'm up for the challenge. Just 2 questions for you experts:
1. Does anyone know where to get the LM4562 in the UK?
2. Is the conclusion that we don't short the 22uF caps now?
Cheers.
__________________
Rig 1: Marantz CD6000 KI » IXOS XHA203 » HeadFive #300 » AKG K701
Rig 2: iPod Shuffle » Zu Pivot » LDM+ » Etymotic ER-6i
Rig 3: Lenovo S10 netbook » Audio Technica ATH-ESW10JPN
Photoblog: http://duane.shutterchance.com
Head-Fi'er
Originally Posted by janderclander14
With respect to the op-amp caps, I preffer not to sort them but replace the full set of 16 caps with higher value ones.
Which cap value do you recommend (that can fit in the available room)?
As they seem to provide current and not transport signal, does high quality cap is really needed in this case (I suppose exchanging 16 blackgates will be quite expensive)? Do standard nichicons may be enough?
Thanks again to cotdt for this awesome thread!
http://www.head-fi.org/forums/showpo...9&postcount=89
i asked almost the same quesion. although, i dont know if the same advice still applies?
__________________
.flac .mp3 320k
03-20-2007, 06:29 PM
Head-Fi'er
Cheers.
1.
Opamp:
http://catalog.digikey.com/scripts/p...me=LM4562MA-ND
Power Filter Capactor:
http://www.hificollective.co.uk/comp...dard_type.html
2.
I think so
__________________
.flac .mp3 320k
03-20-2007, 06:45 PM
100+ Head-Fi'er
Thanks a lot Gilly!  I had thought Digikey was a US site, but just saw a UK section. That really helped.
__________________
03-20-2007, 08:01 PM
I think the limit might be the DAC itself in this case. For example, I expect a better DAC like the Elite Pro to score better. But this X-Fi already scores very well stock.
03-20-2007, 08:07 PM
unfortunately, no one is sure what exactly these capacitors do, so there is no definitive answer. i know some DAC chip engineers at CS so maybe i can ask them when i get the chance. however, the card does sound a little better shorted. if they were "critical" then if you short them then they shouldn't work at all, or sound strange. to be safe, you can try 22uF 16V Blackgates in that position. if there is any improvement then let us know. if not, then all you lose is a few dollars. i suppose 22uF polypropellenes would be too big, but the actual value does not seem to be critical.
03-20-2007, 09:11 PM
Head-Fi'er
A little more info about caps roles:
http://www.avsforum.com/avs-vb/showt...&#post10070526
Cap modding for an Elite pro (sadly in japanese, but the pics may help):
http://www.geocities.jp/tag627/X-Fi.html
03-20-2007, 09:24 PM
"Anyway, I shorted out the capacitors for the front 2 channels using small pieces of wire between the capacitor pins. I would say that the sound was a bit brighter and sounded a bit more real - especially for vocals. I measured dc voltages of less than 1mV for both front channels (with no sound playing)."
Very interesting, and in fact bclare's findings mirror mine exactly. Although the caps make the DAC more stable, they are not needed in this situation. Since capacitors degrade sound, they should be removed if they are not required. Manufacterers like Creative don't care about sound quality as much as a potential lawsuit where they could lose millions, and they have no idea what kind of equipment will be used with their card, so I can understand why they would want to play it safe.
Since 3 different X-Fi cards have had their caps shorted with no ill effects but in fact an improvement in sound quality, I would definately recommend shorting these caps.
03-20-2007, 10:05 PM
100+ Head-Fi'er
I just modded the output opamp. I did not touch the input stage. Perhaps that is a source of distinct limitations.
The card is an elite pro. All parameters were that same (bit perfect, with all audio "enhancements" off, and volume at 90%).
I have listened to the card, before and after. The biggest changes for me was to plug my headphones directly into the card itself and not into the breakout box. Large difference between breakout box and direct out from sound card.
[rant]
This is a nice card. I have not heard the uber expensive DAC or DAC / Amp combos, but I like the sound. I like the music it makes.
Perhaps this is due to the eilte pro's inherent quality to begin with? I think Creative has made a very very good product here. I do not think it is a trade off any more between gaming and audio fidelity (at least with Windows XP). From my perspective, get the elite pro and then use it with all bells and whistles for gaming and switch to audio creation mode for the audio fidelity.
I keep wondering about all the questions here at headfi on what DAC or Amp to upgrade to (assuming upgrading from Xfi). I think this is a great card. Creative has made bad first impressions with a lot of the sound blaster line, but the elite pro is something else.
[/rant]
I have to admit my own personal limitations. If the modded card and the stock card were to be A/B tested, I may (low probability) be able to tell the difference. Not being able to A/B test, I can not make a statement that it is that different. That is a personal limitation.
While I was making the mod I fired up the integrated audio on the Bad Axe 2. It is the Intel HD audio. Now that was a huge difference from the modded elite pro and the integrated audio! My lord, I was modding as fast as I could to get away from that!
__________________
Feedback
03-20-2007, 10:11 PM
Head-Fi'er
[rant]
[/rant]
i agree, onboard is pants without an external dac etc.
and tbh, your elite pro comes with some by all acounts amazing DAC's anyway. i think that you were "spoilt" with good quality before :P
__________________
.flac .mp3 320k
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
