Head-Fi: Covering Headphones, Earphones and Portable Audio
  #16 (permalink)
Old 07-05-2009, 06:33 AM
500+ Head-Fi'er
Default
Originally Posted by Menisk View Post
I might be wrong. But I'm not sure if you can still use ASIO in Vista. You might be able to but there is also the option of WSAPI, which foobar also has a plugin for.
And also, don't be too worried about not being able to tell the difference. Once you've been listening to FLACs on a decent system for a few months your ears kinda learn to pick the details out of the music and when you go back to 128k MP3s you'll notice in an instant that the detail you were previously picking out isn't there.
You can use Asio in vista no problems,I still use my RME Digi card even though Vista does not recognise it as such.
Do not believe that old night and day bit to much,what is N & D to one is not to another.
Why not listen to a CD with your eyes closed whilst relaxing,then do the same with the mp3's.
If you can still not pick a difference,get your hearing checked out.
  #17 (permalink)
Old 07-05-2009, 07:30 AM
KingStyles's Avatar
500+ Head-Fi'er
Default
I never did a direct comparison before but I picked the right one in the sound test and that was between 128 and 320. Vs flac would be an even bigger gap. You couldnt hear the roll of the highhats in the 128. Like rolling your rrrs, the highhat rings were monotone and didnt vibrate like in the 320. Also the 128 was compressed like you were listening in a sound absorbing room.
  #18 (permalink)
Old 07-05-2009, 09:33 AM
krmathis's Avatar
10*2kai
Head-Fi's Most Prolific Poster
Default
First you say you can not distinguish between MP3 and FLAC, then later on you say "85% of the time I don't notice any difference". Which imply that you can indeed distinguish between them, 15% of the time.
That is probably as high as anyone can get. As transparency varies a lot between different music..
Busted!
__________________
:: Feedback ::
MacBook Pro → Isabellina → Signature 30.2 / β22 → K1000
MacBook Pro → Isabellina → Signature 30.2 / β22 → SRD-7 Pro → SR-007BL
  #19 (permalink)
Old 07-05-2009, 11:16 AM
uraflit's Avatar
Default
^ wouldnt it be ~50%, since you can literally guess either MP3 or FLAC... 1 of 2 chance!
lolol
__________________
E-MU 0404 USB
Denon AH-D2000 ///Audioengine A5B /// Sennheiser HD25-1 II /// KOSS KSC-35
  #20 (permalink)
Old 07-05-2009, 03:06 PM
ph0rk's Avatar
Default
Or he won't. Not everyone can pick out the mp3 artifacts without training, and modern encoders have been improving their 128kbps encodings for years.
To the OP: don't worry about it if you can't hear much difference (once you're certain you're playing back good samples without any resampling). You enjoying the music is more important than you being able to detect how it was encoded without looking at the tags.
__________________
semantics are everything
For Sale: SE210
. . . K601
  #21 (permalink)
Old 07-05-2009, 11:21 PM
Prog Rock Man's Avatar
500+ Head-Fi'er
Default
Originally Posted by leeperry View Post
when I start spotting mp3 artifacts(like at 0:06 in that test), I just can't enjoy music anymore
224kb or more is acceptable, but they never sound as genuine as lossless...which is the real deal, no wooshy wooshy/distorted sound to ruin my enjoyment
I took the test, listened a few times to each sample and did not bother to find out which is which as that would have been a guess. I would then either kid myself I can hear the difference, or would get annoyed at not being able to tell the difference.
All due respect to you leeperry, your hearing is better than mine. But I would rather be in my position of easier satisfaction and enjoyment than yours of noticeing artifacts and not being able to enjoy a track anymore.
__________________
Main rig: Spotify Premium+ itunes+ Sony Vaio+ Firestone FubarII USB DAC with Supplier+ Musical Fidelity X-CANV8P+ Goldring NS1000+ AKG K702.
Other rig; ipod Classic+ RA GQ-24 interconnect+ Musical Fidelity X-CANS mods by Rock Grotto+ Grado SR80
Portable; ipod Classic+ nano+ FiiO E5+ LOD+ Sennheiser mx500+PX200
  #22 (permalink)
Old 07-06-2009, 05:19 AM
Head-Fi'er
Default
I can definitely tell the difference between FLAC and 128, but from 192 and up it gets sort of mushy.... Pandora One's 192 sounds fine to me. Can some of you seriously distinguish 320 and FLAC?
  #23 (permalink)
Old 07-06-2009, 09:38 AM
leeperry's Avatar
Default
the brain is a poor measuring tool. hearing a difference between ASIO/KS and DS+Kmixer in an A/B comparison can be difficult(but possible!), you can actually measure KMixer's distortion w/ WaveSpectra
you can also measure 320kbit MP3 distortion against WAV w/ WaveSpectra as well : http://www.head-fi.org/forums/5785853-post42.html
all these figures add up in the end, and if you want the cleanest possible source....mp3 is not an option.
and to answer your question? I haven't really tried, but I've got a pretty transparent setup and lossless just sounds pristine...192kbit sounds like it's missing a lot of stuff in the back, 224 and up sound OK...yet the trebles still sound a tad distorted over lossless. ...why bother?
and the worst the source material(70's acoustic music), the worst it'll come out. distortion and hiss don't compress well.
__________________
"If there is one thing I have learnt about experts, they're experts on **ck all." Jake Green, Revolver
  #24 (permalink)
Old 07-06-2009, 05:38 PM
backtoreality15's Avatar
100+ Head-Fi'er
Default
+1, There's a huge difference between 128 mp3s I've had from the late 90s to the ones I run into now.
__________________
Head: Klipsch S4
Room: Audioengine A5
DAC: Musiland SVDAC06
"But you did not persuade me, Nicholas. You did not persuade me!" -Forest Whitaker as Idi Amin
  #25 (permalink)
Old 07-06-2009, 05:56 PM
BigTony's Avatar
500+ Head-Fi'er
Default
On my music server I have probably only 1% mp3 (which I'm trying to irradicate) these range from 128-320kbps - everything else is in FLAC.
Pretty much everytime I play a song and go.. humm sounds like an mp3.. sure enough it is one - there is something about the artifical bass boost that I seem to be able to pick up without any problem.
On the downside it means that I'll have to hunt down that pesky 1% and replace it all one day.
__________________
Home : SqueezeCenter 7.3 -> Squeezebox3 -> Audio-Gd DAC-3SE -> (Audiotailor Jade) La Figaro 332S -> HD 650/Grado HF-2
Away : Ipod 160GB/Vaio Laptop -> LOD/USB -> IBasso D3 -> ER-6i/DT 770
  #26 (permalink)
Old 07-06-2009, 06:24 PM
ABathingApe's Avatar
500+ Head-Fi'er
Default
I concur!
On a side note, even listening to things that are listed as 320kbps may not be truly 320. Back in the day, when using the gnutella network, you'd find lots of 320kbps files that sound like absolute garbage, most likely upconverted from lesser files. And we all know you can't create resolution. Where you get your files is important.
  #27 (permalink)
Old 07-13-2009, 09:18 PM
Premier Sponsor
Lavry Engineering
Default
Originally Posted by ABathingApe View Post
I concur!
I have not listened to many downloads or streaming audio, I mostly listen to CD's, but I did plug my DA11 to the laptop via USB cable and looked around at Pandora on the web.
For now, I think Pandora may be usable for the purpose of quickly LOOKING FOR MUSIC on the web, but when I find music I want to listen to, I will order a CD.
For reference, a CD offers 2(channels) X 16(bits) X 44100(samples per second per channel) = 1411.2 kbps
Pandora offers an upgraded per fee service for $36 a year. They state:
"High Quality 192Kbps audio streams, the highest quality streaming audio available on the internet".
Comparing it to 16bit at 44.1KHz stereo (CD format), we have data that is compressed by 7.35 to 1 ratio. I do not know what the standard free Pandora offers, perhaps 128Kbps???
Of course streaming audio is the slowest. Downloads of music files (non streaming) offers much better audio quality, but it takes time to download and space to store. Both the speed and storage are improving fast, and I can not wait for the day that audio compression will be a thing of the past.
Well, one could adopt a lossless audio compression schemes but the maximum ratio is only about 2 to 1. If you go further, you are taking a bite out of audio quality.
Regards
Dan Lavry
  #28 (permalink)
Old 07-14-2009, 04:44 PM
500+ Head-Fi'er
Default
Regards
Dan Lavry
Hi Dan,
Thanks for your response. I am of course familiar with the bit rates involved with CD-quality, those of which are seen from normal CD -> WAV rips. You did not mention that the compression curve is normally not linear, and varies depending encoder even within formats. Thus not only do recordings feel like they are lacking detail but in certain frequency bands, more detail is lost than in others. Granted, judging by your website and all of your experience you have a huge wealth of knowledge. I do agree with you in the sense that listening to music online then buying is a great way to do it.
  #29 (permalink)
Old 07-14-2009, 08:27 PM
Premier Sponsor
Lavry Engineering
Default
Hi Dan,
Thanks for your response. I am of course familiar with the bit rates...You did not mention that the compression curve is normally not linear, and varies depending encoder even within formats. Thus not only do recordings feel like they are lacking detail but in certain frequency bands....Granted, judging by your website and all of your experience you have a huge wealth of knowledge. I do agree with you in the sense that listening to music online then buying is a great way to do it.
Hi,
I could not cover everything in one post. I agree that is some sense, the "compression curve" is not linear, but the whole concept is a bit fuzzy. Such a curve has 2 dimensions (axis). One dimension is very clear – the bit rate in say kbps. One can attach a clear number (such as 128kbps). But how does one quantify the other dimension - audio quality? Is that to be based on an “average listener”? On a listener with exceptional hearing? On a “trained ear”?
As I already said, I can not wait for the day that audio compression will just go away. Newer storage technology is almost there - we already have massive flash ram and hard drives at lower cost, and every year the industry offers much more... The internet speed is also going up fast. It was not so long ago when I upgraded my modem to 56kbps (well, that is the perspective of 64 years old).
Regards
Dan Lavry
  #30 (permalink)
Old 07-14-2009, 08:55 PM
dex85's Avatar
100+ Head-Fi'er
Default
i ABXed 192 kbps mp3( 3.98 LAME, CBR, joint stereo) vs flac with 9/10 result on Essence STX. it was with stock op-amps, so your soundcard is capable of revealing the difference. on the other note, it took me more than an hour to do so with 50 seconds long song. afterwards i swore i would never do the ABX again
i didn't pass the 256 kbps. i too think it will come with time as your ears get trained, and if not don't worry about it. just enjoy the music.
__________________
Foobar2k(Wasapi) -> Asus Xonar Essence STX (2xJRC2114D @ I/V + LME49720HA @ buffer) -> Lehmann Audio BCL -> AKG K701
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
How to distinguish between HP-2 & HP-3 by appearance? nichifanlema Headphones (full-size) 9 09-21-2006 12:20 AM
How to distinguish C7 and C8 in TREAD kit applegd DIY (Do-It-Yourself) Discussions 2 08-18-2006 07:58 PM
I need an archiving system (FLAC? ALAC?) viator122 Computer Audio 14 04-21-2005 03:42 AM
Cosmic System (current model): Douglas256 Headphones For Sale / Trade 7 12-13-2003 01:49 PM
Do you satisfy with your current system? PC Corp Headphones (full-size) 0 03-13-2002 10:56 PM
Flickr/Twitter
Follow headfi on Twitter!
See Head-Fi photos on Flickr!
Head-Fi's Sponsors
(Premier Sponsors bolded)
Head-Fi Blogs
and Facebook
Check out Head-Fi's new
Blogs section.
Featured Head-Fi Blogs:
Jude's "Take My Word"
 From Japan - by Sasaki
Currawong's Blog
Start your own Blog!)
Attention
Facebook Users
Join the official
Head-Fi.org
Facebook Group
Flickr/Twitter
Head-Fi's Sponsors
Powered by vBulletin® Version 3.8.5
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.3.2
Head-Fi.org
