Support Head-Fi.org by starting all of your Amazon.com shopping by clicking here.
____________________________________________________________________
Today's Featured Head-Fi Blog:  Jude's Blog
Please help support Head-Fi by becoming a Contributing Member  CLICK HERE
-- Contributing Members, thank you for your generous support! --
Head-Fi Is Sponsored By:
Register FAQ Blogs Members List Calendar Mark Forums Read Today's Posts Search
Head-Fi's Sponsors
(Premier Sponsors bolded)
Featured
2008 International
Head-Fi Meet
(Can Jam '08)
Impressions,
Reviews, Photos
Can Jam '08 graphic
courtesy of Edwood
Click on the links below
for Can Jam '08 photos,
impressions and reviews:
NightWoundsTime
lan
agile_one
wavoman
crappyjones123
Luke G
bperboy
jimaxp
Can Jam '08 Logo
T-Shirts For Sale
Head-Fi Blogs
and Facebook
Check out Head-Fi's new
Blogs section.
Featured Head-Fi Blogs:
Jude's "Take My Word"
 From Japan - by Sasaki
Start your own Blog!)
Attention
Facebook Users
Join the official
Head-Fi.org
Facebook Group
Head-Fi's Sponsors
Featured
Go Back   Head-Fi: Covering Headphones, Earphones and Portable Audio > Equipment Forums > Computer Audio
Computer Audio Discussion of computers as source components, sound cards, USB DACs, media servers, etc.
Meier Audio CORDA HEADSIX & The Most Recent Sponsored Threads
Celebrating 6 years of Head-Fi, Meier Audio introduces the Limited Edition HEADSIX (portable headphone amp) Head-Fi Support Sales Action
Reply
Thread Tools Display Modes
Old 07-15-2008, 02:30 PM   #31 (permalink)
500+ Head-Fi'er
vvs_75's Avatar
Profile
Default
Originally Posted by cerbie View Post
I hope that helps and doesn't confuse you too much.
No you didn't confuse me, you scared hell of me!
Thanks for your help! Your guide for dummies will help me through out the process.
__________________
My Feedback:
http://www.head-fi.org/forums/f12/vvs_75-a-204966/
vvs_75 is offline
Old 07-15-2008, 03:01 PM   #32 (permalink)
500+ Head-Fi'er
vvs_75's Avatar
Profile
Default
Originally Posted by Hookem View Post
Here are some pics of the CM690, Intel Q6600, Corsair 520HX, Abit IP35-Pro, 2x2gig G.Skill, MSI 9600GT, Thermalright 128SE with 3 6400AAKS's.
Thanks for the pics. Sometimes pictures tell more that words.
I am definitely will get Corsair 520HX.
After seeing HTPC cases, having hard time to decide if the nice look worth the trouble. Plus they are more expansive then regular tower cases. Does they worth the trouble?
__________________
My Feedback:
vvs_75 is offline
Old 07-15-2008, 05:41 PM   #33 (permalink)
100+ Head-Fi'er
Profile
Default
I was using the follow part to build mine:
The case is:
Antec P182 ATX Black Mid Tower Case 4X5.25 1X3.5 6X3.5INT No PS Front USB Audio Firewire (P182)
Use 3-4
Noctua NF-S12-1200 120MM Ultra Quiet Cooling Fan 1200RPM 81M3/H 17DBA Molex to create 2 stable but quiet air flow - one for CPU one for video card
Use this without fans
Thermalright IFX-14 Heatpipe CPU Heatsink Cooler LGA775/AM2
Use this PS and install HD in front of it so the heat of HD will be suck out too.
Corsair CMPSU-620HX 620W ATX Triple 12V 50A 24PIN ATX Modular Power Supply 120MM Fan 2X PCI-E
For the video card use the asus fanless one:
ASUS Radeon HD 3450 600MHZ 512MB 800MHZ DDR2 PCI-E DVI-I HDCP VGA HDTV Out Fanless Video Card(or something like it)
If you want you can upgrade the 2 case fan from antic to Noctua and install a fan speed control.
Just my 2 cents about quiet a PC.
alxwang is offline
Old 07-15-2008, 07:29 PM   #34 (permalink)
100+ Head-Fi'er
Profile
Default
I noticed no one really looks for smaller enclosures, so I'll throw in another option:
Enclosure: In-win BK635 ::::::::::IN WIN::::::::::
It has a decent 80+ efficient PSU. Can hold 2x 3.5" drives, and a 5.25" drive (DVD-burner or Blu-ray). It supports normal components and full height cards in all slots in the smallest package I know of. It's specificly made to Intels specs, and very, very quiet when paired with stock Intel components.
Board: Intel DG45ID Intelฎ Desktop Board DG45ID - Overview
It only has one PCI slot, but really: do you need more? On-board video is capable of playing Bluray. Seen it: it works. And on-board video uses less power than most normal videocards. Plus it's passive.
CPU: If you want to use it for HD video: E7200 or E8x00. You'll want to wait till monday to get this one. Otherwise just get an E2200 (or lower).
LeonvB is offline
Old 07-15-2008, 08:02 PM   #35 (permalink)
500+ Head-Fi'er
compuryan's Avatar
Profile
IM Contacts
Send a message via AIM to compuryan
Default
If you are trying to build a really quiet pc, I would avoid smaller cases. The cramped spaces tend to cause things to get hot inside, and thus your fans will have to blow more air to keep things cool (making things noisier). A bigger case has more room for the heat to radiate.
__________________
Home: Foobar (FLAC) > Audigy 2ZS > BJ 1694A > modded Benchmark DAC1 > Zu Gede RCA > Cayin HA-1A > HD650 w/ APSv3
Portable: Sansa E280 (Rockbox) > PMX100
My Feedback
compuryan is online now
Old 07-15-2008, 09:35 PM   #36 (permalink)
100+ Head-Fi'er
Hookem's Avatar
Profile
Default
Well HTPC cases have gotten much better...But generally speaking they are not very expandable...Most only hold 2 hard drives...Some just one...They usually have very poor theramal performance...The power supply's are really not good for a modern computer...Alot of them are limited to microATX boards.
I bought a Antec Fusion and put together a system using a Abit AN-M2HD microATX board.
Promptly took it out and sold the case.
I have not looked at them lately.
But the nice ones are very expensive.
Unless you are going to use it in a HTPC enviorment like sitting under your TV with your surround sound system then I would stay away from them.
On the case thing...Just make sure you buy a case that has 120m/m fans.
The CM690 is not a small case.
I personally like Lian-Li cases...Here are some pics of the PC7B Plus II
It is a mid tower with a windowed door...That is why all the wires are stuck out there where you can see them...It has UV black lights and all the blue stuff lights up.
I have some other pics of it if you would like to see them with the door on all finished up.
__________________
If you build it...They will come...And I will crash it !!!!
Hookem is offline
Old 07-16-2008, 05:33 AM   #37 (permalink)
100+ Head-Fi'er
Hookem's Avatar
Profile
Default
If you can say how much you want to spend it would be much easier to recommend a complete parts list, soup to nuts, that will give you the best bang for the buck within your budget.
__________________
Hookem is offline
Old 07-16-2008, 05:37 AM   #38 (permalink)
100+ Head-Fi'er
Profile
Default
Originally Posted by FasterThanEver View Post
Basic choices:
- Hard disk - make sure it's big enough to hold your current and anticipated music collection. I've used both Seagate and Western Digital and found them reliable and fairly quiet. If I need another hard drive now, I'd consider a Western Digital green power 1 TByte drive. uses less power than conventional 1 TB drives and is probably a bit quieter. Hard disk manufacturers all have production problems so your experience may depend on your luck. All hard disks are functionally similar for 2 channel audio playback.
Bill
+1 on the GreenPower drives. The have a few of these drives and they're the quietest drives I've ever owned. Best part is that they produce VERY little heat even under heavy loads.
david21 is offline
Old 07-16-2008, 05:38 AM   #39 (permalink)
100+ Head-Fi'er
Profile
Default
Now that's a nice and clean looking rig you got there!
david21 is offline
Old 07-16-2008, 06:00 AM   #40 (permalink)
500+ Head-Fi'er
compuryan's Avatar
Profile
IM Contacts
Default
Hookem, I have that exact same case, the PC-7b, I absolutely love it. It really has that "elegant simplicity" thing to it, don't you think? heres an older pic of mine, I have since changed some things:
Lian-Li cases are always an excellent choice.
__________________
My Feedback
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
building a system from scratch with 1000$ budget ok computer Headphones (full-size) 44 06-10-2008 06:05 PM
Advice for building starter system from scratch? fdjjfdsa Dedicated Source Components 11 05-06-2007 07:23 PM
Advice on building a computer as a source for a hifi II: Quiet PC components its_cheez Computer Audio 59 09-14-2004 05:33 AM
Building a PC. Feedback welcome! redshifter Members' Lounge (General Discussion) 43 08-11-2004 09:18 PM
Building rig from scratch, uncertain and confused. dddmt Headphones (full-size) 6 06-29-2004 09:10 PM
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.2.0 Head-Fi.org
