Support Head-Fi.org by
starting all of your
Amazon.com shopping by
clicking here.
____________________________________________________________________
Today's Featured Head-Fi Blog: Jude's Blog
Please help
support Head-Fi by becoming a Contributing Member
CLICK
HERE -- Contributing Members, thank you
for your generous support! --
Some of the wires the shure used for headphones deteriorated with long term contact with some people's skin oils...at least thats the common thought.
Shure doesn't hesitate at all to replace your phones if you have this problem meet the warranty requirements.
I've had e4s and e2s and neither of mine suffered this malady. A friend of mine had his first pair of e2 wires crack and split. He was very happy with shure's customer service in getting his problem solved.
For a while, I'd been looking for either a paint-on or spray-on rubber-like material to coat the wires and prevent the cables from cracking.
I had been thinking about this for some time and asking as many people as I could if such a thing existed -- everyone told me no.
Well, I found something I am pretty sure (time will tell) will totally eliminate the cable cracking problem. It's something called "Liquid Tape", and it's exactly as its name sounds. It's liquid electrical tape.
I can't tell you all how happy I am to have finally found exactly what I was looking for!
I masked off the buds and the connecter with some tape and sprayed on the rubbery stuff on the wires...it dries in about 20 mins. The cables totally retain their flexibility, and you can peel it off (it takes a bit of work) if you don't want it there anymore.
Just wanted to share a little find with my friends here!
Thank you for sharing that....sorry to bring up and old thread...but you said time will tell if this has worked.....so has it worked for you? Thanks
I also wanted to ask all those who use the warranty, did they require a receipt? I cannot find mine for the life of me
__________________
Headphones: Shure SE310
Music Player: 2nd gen Shuffle
I have tried Liquid electrical tape and it didn't work with my E2Cs. It was quite stiff and even the LET cracked after awhile of use.
Maybe a better idea is tube of memory plastic. Cut the cables near the Y, add the tubes, and solder. If you do a good enough job with the solder it shouldn't look too bad. Look at the cables from Livewires to get an idea of what I mean.
__________________
JVC Air Cushion/FX66
Beyerdynamic DT 770 Pro 80ohm w/Black gel pads
PA2V2
Ipod 80GB 6th gen w/LOD
Creative X-Fi Fatal1ty
My progression:
MDR-V700DJ -> MDR-XD400 -> DT 770 Pro 80ohm
MDR-EX51 -> EX71 -> EX81 -> Shure E2C -> V-Moda Vibes -> JVC Air Cushion/FX66
Wish list:
Livewires
Or Ultimate Ears.
__________________ Home: KECES-151 + Stax SRM1/MK2 Pro + Stax SR-Lambda Pro Portable: iPod Classic 160GB or Sansa Clip 2GB + Koss KSC75 College:iPod Classic 160GB + Little Dot I+ + Grado SR-225 College (2):Laptop (Gateway P-6831FX) + Asus Xonar U1 + Koss KSC75 Cables: IeGO (x2, copper and silver-plated)
There are those who treat music as a convenience.
And then there are those who recognize it as an art. http://www.head-fi.org/forums/f12/th...ngmule-222217/
