Head-Fi's Sponsors
(Premier Sponsors bolded) |
Can Jam '09
(2009
International
Head-Fi Meet)
Impressions,
Reviews, Photos |
Can
Jam '09 graphic
courtesy of Edwood
Click on the links below
for Can Jam '09 photos,
impressions and reviews:
blubliss
1,
2,
3
dallan
1,
2,
3,
4
santacore
1,
2
nhat_thanh
1, 2
vpivinylspinner
1,
2,
3
amb
1
augustwest
1
eaglejo
1
johnsonad
1
shellylh
1
Jon L
1,
2,
3,
4
Germancub
1
zippy2001
1
IPodPJ
1
bhd812
1
Edwood
1,
2
abellaw
1,
2
minidiscs
1
atothex
1
HighLife
1
achristilaw
1
SiBurning
1,
2,
3,
4
SiBurning
5,
6,
7
LFF
1
Iron_Dreamer
1
doping panda
1
morphsci
1
ironbut
1
shaizada
1
jasper994
1,
2
jp11801
1
Uncle Erik
1
drubrew
1
(More impressions/photos
still being added.)
Head-Fi Blogs
and Facebook |
Head-Fi's Sponsors
| Headphones (full-size) Discussion of full-size headphones. |
06-13-2008, 04:33 PM
Sounds reasonable so far.
__________________
♥ MS Pro"Ultimate", DT880CB, , K271, PK1, ANC7----₪ Rockhopper Millet, DIY-Cmoy
Gone: MS1000, CD3000, MS2i, DT990 (~1990), DT770'250(2003), DT531, HD595, A900, K81, PX100, KSC75, Portapro, EP630, pimped BTech
Meet Junky----Adored: MS Pro "Ultimate", AD2K (cotton mod), CD3000, PS1000, K701, W5000, HD800, SR4070, MS1000----Liked: Lambda Pro, DT880'03, DT880'05, MS Pro, SR404/303, K271, A900TI, W100, US E9, MS1, PS1, MS2i, HD650, GS1000, K601, W2002, W10, DT770(2005), D2000, ANC7, PK2, MB Quart 400, ES7, DT531, Proline 900, PX100, SR202----Accepted: HD600, K1000, DT770(2003), A900/950LTD, DT990, HD25-1, SJ5, W1000, SR225, D1000, K24, K401, SR325, Proline 900, HFI 680, K530LTD, K240 Sextett MP, CD480, KSC75/PP----Disliked: AD2K (stock), SA5000, SR007, HD5*5, V700, EP630----Hated: DT770M, K240M, K26/27
06-19-2008, 09:05 AM
I've just got the Dark Audio liberators... and I have two questions:
1. Are all the commercially made Dark Audio liberators made the same? Do they all fit every Grado/Alessandro model?
2. If the liberators can be used with my Alessandro MS Pro, would anybody show me how to do it? The diameter of the wood cups of my MS Pros on the thick side are the exact same length as the liberators themselves, and just a tiny bit smaller than the other side, so it will no slide in at all.
I'm really stuck on how to install this thing, let alone "take off the holders from the capsule" as the Dark Audio site says. Please help me before I break something
06-19-2008, 09:19 AM
Nickchen, i just wanted to tell you your work fantastic...i wanted to know if you have some extra woody cups for SR60/SR80 (same diameter correct) you could send to the US.
I dont care what they are made of, dont care if the wood doesnt match (screen would be great if they matched). Payment will of course be in order =) Im looking for the cheapest possible, so maybe thought to ask first. Since they going on the SR60s, im trying to build a budget woody =)
I dont mind some knicks or maybe some sanding finishing work needed.
Let me know if thats possible.
__________________
Headphones: Sennheiser HD-650's + Enigma Audio Oracle cable, Shure SE530, RS1 (Classic B), Grado SR-125 & HF1 (loaners), Sennheiser MX500
Sources: -Squeezebox v3 (Thanks Ingwe) + Headroom Micro Dac - Ipod 120GB Classic - Samsung T9 4GB - Headstage Lyrix Total USB/Asus G1/Foobar-Flac
Amps: Headroom Desktop Millett Hybrid #1 (Home upgrade/12FK6 tubes) + Headroom Desktop power supply - Headstage Lyrix Total USB
Speakers: Cambridge Soundworks Model 12's (Squeezebox - HR Micro DAC-HR Millet Preamp-Model 12's)
My Feedback My Heatware Did you listen to my old rig at CANJAM '08?
06-19-2008, 09:57 AM
Hey Assorted, Glad you got the libs okay.
I am not sure about your first question, but to remove the holders you just gently slide one part of the "C" out of the hole to the side and then the other side of the holder. Do it one side at a time gently so you don't crack your C clamp.
The libs go (with the thicker side) onto the plastic side closer to your driver. It should slip on easily. They were actually a little loose on my grados before hand. The site says that they should fit the rs-1 and rs-2 as well, so I imagine your ms pro should be okay as well. Anyway, then put the c clamps back on to the holes in the libs and you should be set.
hope that helps.
__________________
rig in flux - filipelli
what i love right now: thinkpad x301, sony a728
06-19-2008, 11:58 AM
Two cold showers:
As far as I am informed, they are all the same. They fit on SR60, SR 80, SR125, SR225, SR325, MS1, MS2i - but not on the MS Pro or the RS1, as these have a thicker diameter. Really sorry, but I doubt that you can use the Liberators.
Possible solutions: Organize or build yourself distancers, or cut the "distancer share" from the Liberators. Glue whatever you use, and if you want it reversable, use blue tac, silicone, etc.
Originally Posted by HighLife
I wanted to know if you have some extra woody cups for SR60/SR80 (same diameter correct) you could send to the US. Since they going on the SR60s, im trying to build a budget woody =)
HighLife, I am able to build woody cups as to be seen on the pics, but problems remain the actual €/$ exchange rate of 1.54 and the immense costs (40ish €) for insured shipping. Therefore I doubt that I can offer you a budget solution right now.
Beware of too high expectations in respect of "sound improvements" anyway. I recognized next to nothing and have the suspicion that raving of woodying might often has to do with fanboyism or financial interests. Woodying is for the eyes and the ego only IMO (my ego is pretty content  ).
__________________
06-19-2008, 01:32 PM
I'm 1/3 of the way there now.
The distancers arrived this morning, so now i'm just waiting on the ms1 and pads to turn up so i can get assembling and try this bad boy out.
__________________
Home Rig:. Sony SACD •♫• Technics SU-V303 Amp •♫• AKG K1000
Portable Rig:.Sony X1050 •♫• Livewires SPC recable / Ms1000i
Feedback:♪ Head-Fi..ebay
06-19-2008, 02:03 PM
Wow, the altered shipping logistics aren't just cheaper, but also quicker by the factor of 2.
__________________
06-19-2008, 03:24 PM
Dang, it says compatible with RS-1 on the Dark Audio site...
06-19-2008, 03:50 PM
Where did you dig these Liberators?
__________________
06-19-2008, 03:53 PM
100+ Head-Fi'er
I too have the distancers with ms1 and awaiting the pads. Will give some impressions when it is all here.
I also have some recabled 325s which I could try this mod with no?
James
06-19-2008, 04:35 PM
You can at least try it with the SR325, maybe by means of provisorical fixation of the distancers. But after what we've experienced with the MS2, I doubt that the result would be as coherent and impressive as with the MS1 or the MS Pro. The mod tends to increase the highs, and that isn't to be desired for a SR325 IMO.
__________________
06-19-2008, 05:09 PM
100+ Head-Fi'er
Ah good point! I think I will just put it on the MS1s for now. The highs are what is really missing on these. I've had to stop listening to them because of the lack of detail in the highs (with flats at least).
06-19-2008, 05:17 PM
500+ Head-Fi'er
But wait, wasn't there speculation that the 325i used the same driver as the GS1000?
So if you put on the distancers and the big bowls, wouldn't they almost be the same headphone?
__________________
Headphones: Grado RS-2 (w/ buttons), Beyerdynamic DT880 ('05 250 ohm), Shure E4c
Amp: JVC RX-6008V Integrated (amazingly good headphone output), AIWA NSX-AJ300 Integrated, Minibox-E (SOLD), SOHA w/ JISBOS and Blackgates (SOLD)
Source: Keces DA-151
Speaker: Pinnacle Classic Gold Towers
My Feedback
06-19-2008, 06:23 PM
500+ Head-Fi'er
You should get bowl pads they will bring out the highs, don't they originally come with bowl pads?
06-19-2008, 06:38 PM
I think they come with the comfies instead.
__________________
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
