APureSound: The Ultimate Cable Manufacturer Introduces The V3 Headphone Cable
Member of the Trade Sponsored Threads ForumThis is where Members of the Trade will pay for time-limited, topic-specific discussion threads for the purpose of advertising.
Congrats on the new cable Alex, looking forward to hearing the V3! Oh and what's the basis for the design of your new logo?
The logo was designed and drawn by me. It was drawn with the intent of leaving the idea of what exactly it is open to interpretation. I wanted something very original as that is the entire concept and basis of my company.
-Alex-
__________________
Forget the past. Live in the present. Think of the future.
The smaller length cables are geared towards portable recabled headphones (my best guess).
I actually have a special cables designed specifically for portable headphones as you see with the KSC35, EW9, and others on my site.
I am reworking the products page to incorporate cable details and prices directly onto the site that way it is easier for both my customers and myself.
Thanks,
Alex
__________________
Believe it or not, but I had someone have me recable a pair of CD3000's with a cable just under 2ft in length so that they can put them into their MP3 player and put the MP3 player into their shirt pocket. I was amazed with such and order so I figured I might as well add all possibilities.
the new cable looks great. i'm sure they sound wonderful as well, just like all your other cables. love the logo too
one question. are you going to offer different types of XLR connectors for balanced headphones other than neutrik - such as, vampire, xhadow, or furutech.
__________________
1. Meridian G08 »» RSA Apache »» HD600 / HD650 / K701 / SR325
2. Meridian G08 »» HeadAmp KGSS »» SR-007 / HE60 (or with HEV70)
I would be more then happy to use any 1/4in, 1/8in, or XLR connector that is not the standard connectors that I use. There will be an additional cost of whatever the connectors cost + shipping, but I will not charge anything extra on top of that for using custom connectors.
Thanks,
Alex
__________________
Congrats Alex! I will also recommend Alex for amp mods / repair, and know first hand he is very familiar with STAX and the Blue Hawaii, as well as Milletts / SOHA / M³... oh, and the occasional Zap Filter / source mod.
Balanced v3 order incoming... well, once I get some dynamic phones.
__________________
Starters: Cambridge 840c -> ApureSound Balanced IC -> Blue Hawaii -> (Stax reterminated) HE60
Office: Sony DVP - NS775V -> OPUS DAC -> Millett Maximus Balanced -> APS v3 Balanced HD600 OR HD650
I got a question for you, where exactly will you put the APureSound sleeve on the cable ? Directly on the plug ?
The heatshrink can go on a few possible different places depending on what termination type is going to be used on the cable. There are very many different terminations available.
Originally Posted by d-cee
is copper cored silver the same as silver plated copper?
The V2 cable was high grade silver plated copper wire. The V3 is not a plating. The construction of the wire is different so it is no longer a plating. This concept took around 2 years to design and months to be manufactured. In the end it was all very well worth it!
Originally Posted by Electron Tube
Silver plate means there is a thin plate of silver over copper. Copper core means there is is either a large amount of silver over the copper or almost completely silver with a small core made of copper.
You are partly correct, but it is no longer a plating. There is in fact a lot more silver then copper in the V3, but so was the V2. I called the V2 wire silver plated copper because the idea of how the cable is constructed was familiar by many audiophiles and it was a plating.
__________________
Alex, a while ago you mentioned on this board that silver core cables are not good for headphone applications from durability perspective. How does your new design address fragile nature of the silver?
Thanks.
