I know I'm digging up an old thread, but I'm soo tempted to get into vinyl. I love playing my parent's old records when I go over to their house. I just don't know if my wallet will be able to handle it. I would like to get something like a VPI Scout, but then there are so many other costs... cartridge, phono pre-amp, cleaning stuff, dust cover, etc. To vinyl or not to vinyl? hmmm....
Go for it. I was nervous about getting into vinyl, but am so glad I did. It's not as much work as some lead you to believe and the payoff is large. If you stick to used records (as opposed to the $45 200g reissues) you will save money on music.
I'd recommend reading the columns by the Vinyl Anachronist. A quick Google search will bring him up. Plenty of good information and advice.
I started with a stock Rega Planar 3. Those are terrific decks and a bargain used. I'd recommend starting with a quality used deck. You'll save a lot of money and tinkering with whatever you pick up will give you a lot of insight into a second rig. I ended up wanting a low maintenance suspended deck, and I'm very happy with the current setup.
__________________
UNCLE ERIK Vinyl, Tubes & Grado
J.A. Michell Engineering Orbe SE -> Don Garber Fi Yph -> Eddie Current Zana Deux -> Grado RS-1, HP-2 & Beyerdynamic DT48
Moderator Headphoneus Supremus: Moderator and SHAman who knew of Head-Fi ten years prior to its existence
Vinyl...everything worth something in life is worth putting some effort into getting it. That can mean relationships, education, proficiency in a sport or hobby, appreciating fine food/wine and yes even music.
Vinyl can be a PITA. No doubt about it. Quality control varies for the pressings whereas with a CD or a download, one gets an exact copy each and every time. If the disc is damaged, return and get a new fresh one usually in perfect condition. Throw in a silver coaster, press play and enjoy 30-72 minutes of tunes. If you are into digital files...you are limited only by the storage capacity of your computer.
Getting into vinyl = dealing with higher priced new albums/reissuesd. It equals dirty/scratched records when buying used and we haven't even touched on cleaning them.
Getting into vinyl = dealing with fragile cartridges, pairing them up with an arm and turntable and then throwing in a phono stage if your preamp doesn't already have one.
Getting into vinyl = dealing with storing large heavy discs and when playing them, getting up at best every 20 minutes before you have to switch sides.
Getting into vinyl also = access to 1 billion pressed discs far more than RBCDs and it also means exposure to never again recorded music. Gems you can only get on those large black discs.
Getting into vinyl = complete access to your music the way you want when you want. No DRM thank you! If you need to back them up...hook up the system to your computer and record away!
Getting into vinyl = enjoying liner notes without a magnifying glass and beautiful artwork on a large scale.
Getting into vinyl = a tactile experience with your musical collection, something digital in all forms has stripped from the user. With increased ease of use comes a detachment for the user. One gets a sterile experience. Some appreciate this some don't.
Getting into vinyl = what many consider better sound. Analogue is often defined as organic, flowing, life-like or real. It is warm and natural and better than anything in the digital realm. There is a reason why most if not all high end digital device manufacturers advertise that their player of the minute sounds more like vinyl.
Getting into vinyl = access to TONS of music for very cheap. Despite the fact that many new albums cost a lot, there is no doubt that used vinyl is often pennies per album and if one has a discerning eye, you won't get burned with a bum disc.
Getting into vinyl is worth it for many and worth it was to me and still is. I appreciate vinyl more but sadly I listen mostly to digital files or cds because of the convenience factor and time constraints.
Thanks for the info. There are some good deals on Audiogon right now. I'll probably have to wait until the end of the summer to buy one, so I'll have a little more time to think about it.
When the CD was introduced, the hi-fi dealers were high in the hype that the CD had the superior sound quality. Some of us never bought that, and kept our turntables and LPs. In the late 80ies, I remember listening to a classic reccording (Arve Tellefsen on violin) on both
* my medium-fi stereo with vinyl (amp and speakers $600 each, turntable a Thorens with Orthofon slightly more) and
* a friend's hi-fi stereo with CD (NAD's more expensive stuff)
and notice two differences:
1. Vinyl sounded "warmer"
2. There was something just wrong with the CD sound that gave me a headache.
No doubt the CD has evolved since then; I no longer get a headache listening to them. But that first experience marked my relation to the two media. Also, given the CDs inherent limitation vis-a-vis playing complex high frequency music (cymbals sound very jingly in MP3, but the jingliness doesn't disappear in lossless or CD), the LP wins for audiophile experiences. But not for convenience.
But is it all about CD vs LP? Well, I can list four candidates for sound
1. CD (well, this one won't win)
2. 24bit/96kHz digital
3. LP
4. Big Tapes (like they used for master tapes in the old days). Using the full width of a VHS or BetaMax for sound
I think there's a tie between 2 and 3 for second place, but with how expensive equipment? Number 4 however ... can you beat the quality of the master tape? I think not. The master is the master. So maybe the return of the LP is an intermediate stage before we return to those broad tapes (OK, I admit it; I've forgotten what they're called in English!) Or maybe digital will win in the end if we just up the ante; most mastering today is DDD, which means that any LP pressed has been through digital anyway, and you'd get the best results by going to those masters (24bit/192kHz?)
You do of course have the question of cost: maybe equipment that can do justice to the higher-rate digital will be beyond the wallet even of those who build concrete sockets for their $10000 turntables? But then again ... tapes The only area I can see those broad tapes losing out to LPs would be aesthetics.
__________________ Solan
Team wears full-sized cans in public.
Team Wine-fi
Team miniaturization
I have a fairly logical way of looking at the vinyl vs. digital debate, which goes:
You really don't have to spend a ton of money for a good deck/cart/accessories in order to enjoy the benefits of vinyl, really. For those thinking about taking the plunge, remember that it is vital to keep your equipment in perfect shape, so that if you decide to back out of your investment, the resale value of your stuff will be at a peak.
I decided to go with a Rega P2, and at the time was able to get the older model with a glass platter. Today, I might have either chosen to go with a P3-24 with external power supply or perhaps even a KAB modded Technics SL1200, though all three (which includes mine) are extremely worthy entry level decks.
I'd like to think that I'm just as anal retentive about sound quality as most other head-fiers, and can honestly say that the time taken and financial investment I made into the world of vinyl, was well worth it. There are some very simple reasons to back this feeling:
I take comfort in knowing that when I take the time to look for them, well mastered vinyl pressings are out there, which don't conform to the same standards which so many CD masters do. Meaning, I'm able to find out whether or not the pressing was done from the analog master tapes specifically for vinyl, or if it was pressed from the CD. If in the case of the latter, I'll just get the CD for the sake of convenience. Unless however, the production quality on the whole, was really on par. No brick wall mastering, in other words.
The way I see it is, if for every badly mastered CD which is out there, there is a vinyl counter part which was mastered separately and has all the dynamic range etc which the CD is missing, and I'm going to buy those LP's. Of course then, there's the case where the CD was mastered brilliantly, as was the vinyl. In that case, it's pretty much a matter or preference. Collectors are always going to get both versions, while those on a budget will mainly opt for the better $ deal, and then there are those who will make the purchase based on which sound they find more appealing.
But then we have the issue of what kind of system the medium is played back on... A more revealing system will truly make the choice either all the more easy, or perhaps harder ! This can probably go on forever, but to make it short, ones foray into the world of vinyl need not be so dramatic or even time consuming.
I'd probably recommend the Technics SL1200 which is such a low maintenance deck, and really is very durable as well as musical with the right cart. I'll also say the same about the entry level Rega decks. My Rega P2 is equip with a Rega Cart (Elys) which took like zero time to install and adjust. They're specifically made for the arms and are also very low maintenance.
As for overall system maintenance, I just recently bought a record cleaning machine to replace my worthless D4 brush and fluid. I got the KAB EV-1 manual machine, which requires that you own a cannister vacuum cleaner with a hose. It comes with fluid, which I'll not use because I bought some MoFi super deep cleaning fluid and 3 carbon fiber brushes for application. Total cost for all my stuff:
Deck: $550
Cart: $125
That's under $700 for a totally worthy setup. I was using the D4 brush with fluid for the first few months, and wasn't entirely satisfied, though there are tons of LP cleaning techniques which require little $, but plenty of patience. The KAB EV-1 record cleaning machine cost $160 and the fluids about $40 which includes medical grade distilled water for rinsing. Brushes are about $10
All in all, the way I see it is that for the money I spend on stupid crap, this is money well spent on something which is an integral part of my life, and will never cease to exist, and only continue to bring me happiness. And you really can't put a price on happiness, if you asked me.
Edit: Sorry, I forgot to mention what I'm running my deck through. Quite simply, a wonderful receiver. It's the Outlaw Audio RR2150 which has both MM and MC phono stages and to my ears, sounds just great ! Interestingly enough, I also have an old Onkyo TX SV515 Pro which also has a phono stage, and recently found out that it too, sounds pretty decent with my Rega ! So one need not get into fancy or costly phono pre amps... There are alternatives.
__________________
Thanks to Head-Fi, I've learned how to spend money that I don't even have.
"Thank You Head-Fi !"
My Wife > 5th Gen 30 gig iPod w/ROCKbox > ROCKbox Loaded H 20> Sony Ericsson W810i Walkman Phone > UE Sound.fi 5 Pros >Blue JVC Marshmallows' w/small UE ear tips>Blue JVC Marshmallows w/Shure E2 foamie ear tips SonyV6's >My psychopathic cat. (These are things I love)
Deck: $550
Cart: $125
__________________
6) Distortion that increased towards the end of each side of the record.
I'm actually surprised I haven't been able to find more information on this, since I've had two record players and I have noticed this myself. It's probably my only beef with vinyl so far.
Basically what happens is it sounds fine at the start of a side, but as it gets closer to the middle of the record, what it sounds like is the treble frequencies are not clear and muffled, especially when the vocalist pronounces an 'S' or on cymbal crashes, yet the bass frequencies aren't noticeably different. Also happens on 7" vinyl, so this leads me to believe it's related to the angle at which the tonearm is pointed.
Anybody know what could be causing this? Maybe my cartridge isn't high-end enough.
Headphoneus Supremus: Loyal member of Team Useful Post.
I have heard this too, and I forget the exact reason for it. I think it has something to do with the greater curve that the stylus has to make -- i.e. the concentric circles are getting tighter, and the stylus has to move differently. I also remember hearing that this was specifically why most older recordings would have their best songs near the beginning of each side of an album...so as to make best use of the sound quality. Who knows, it was just something I heard at some point. It could be bs.
