You are in TTVJ's Premier Sponsor Forum at Head-Fi.org.
To get back to Head-Fi.org's Main Forums, click here.
Register FAQ Members List Calendar Mark Forums Read Today's Posts Search
Go Back   Head-Fi: Covering Headphones, Earphones and Portable Audio > Premier Sponsor Forums and Sponsor Forums > TTVJ Premier Sponsor Forum
TTVJ Premier Sponsor Forum TTV(&H)J Forum, and TTV(&H)J Announcements
Reply
LinkBack Thread Tools Display Modes
Old 07-13-2005, 12:15 AM   #21 (permalink)
1000+ Head-Fi'er
Little J040's Avatar
Profile
IM Contacts
Send a message via AIM to Little J040
Default
I'm at least interested in hearing some vinyl. I don't really think I will go all out, Just want to hear some of my father's old Pink floyd and Rolling stones albums. Is cleaning them such a big hassle, and finger prints can screw up the record?? More than likely I'll be purchasing a used, 200$ or so TT from a head-fi'er, Just to get a taste. Also have an older reciever with a phono out so that shouldn't be a problem. What else is there for me to get?
__________________
Looking For: Gilmour Lite DPS
Home Rig: Foobar ASIO 2.0 out-> Esi Juli@->MHDT Labs Dialogue II->Gilmour Lite v.2->HD 600\ ATH-A900s\HD 595
vinyl Rig: Music Hall MMF 2.1-> Audio Technica AT440MLa cartridge -> Cambridge Audio 640p phono stage-> Kenwood KA-880SD-> Jamo 68 Bookshelves
Portable Rig: Apple Ipod 15gb->SendStation Pocket dock->RSA Hornet M->Etymotic ER-4s\ Koss KSC-75\ PX200
Previously Owned: SR 125s, MX 550s (eaten by ipod, yes my ipod literally ate the drivers.)
Lent to Mother: Supermacro v.1 OPA 627-> HD 595s
Car Rig: Alpine CDA 9835->Monster cable Rca to mini->Ipod dock line out->"Uncle Ted's Ipod"->2 pair RF Twisted pair RCAs->Rockford Fosgate 501x 1500w 4 channel amp->Phoenix Gold Comp Elite Ti 5.25" Components, 1" tweeter Rockford Fosgate 801s 2 channel 2400w sub amp-> 2 power acoustik Fubr 12" subs 700wrms each->Custom made 3 cu in ported enclosure
Team Etymotic
Team Sennheiszzah
Little J040 is offline
Old 07-13-2005, 10:38 AM   #22 (permalink)
100+ Head-Fi'er
periurban's Avatar
Profile
Default
Aman.
So, the means of solving the problems I experienced is a secret, is it? Or is it only about money? I had thought that these issues were an intractible part of the vinyl experience. I had pals who had expensive systems, but the problems I described above persisted on their systems to varying degrees.
Obviously, things have moved on since the dark eges of the 1980's.
__________________
"Do what you wanna, do what you will, but don't mess up your neighbour's thrill" F Zappa
Grado SR60, Shure E2c, Cyrus Mission 1, Yamaha SW1000XG, Archos gmini400, EAC/LAME
www.periurban.com for free music
periurban is offline
Old 07-14-2005, 05:55 PM   #23 (permalink)
Moderator
Headphoneus Supremus:
Moderator and SHAman who knew of Head-Fi ten years prior to its existence
Profile
Default
Originally Posted by periurban
Aman.
I'll relate some of my experiences with vinyl thus far (I'm quite the newbie, only a few months into this game).
Is vinyl inherently noisy? No. Does it possess the possibility of developing more noise than a digital format? Oh yes. Dust is a nasty thing.
So the cleaning deal. New vinyl needs to be cleaned once because most new vinyl comes in those crappy white paper sleeves that leaves shreds on the vinyl. A brush with a carbon-fiber and then a wet wash and then a dry shoudl do the trick, then a quick dry brushing before each spin and one should be good to go.
I have some older vinyl that is as quiet as cd, it was well taken care of and was kept in anti-static sleeves.
As for sound, vinyl can actually present more detail than digital formats depending on the grade of the gear, the ability of the cart etc. There is one album I own that is brand new, and I have the cd as well. The vinyl has more microdetail, better dynamics and more bass. I believe the majority of the issues stems from the mixing/mastering, and not from the format specifically.
Digital is much easier to live with, very convenient, quick and easy, pretty flawless in identical playback each subsequent spin. Vinyl won't degrade if the cart is setup properly. CD's won't degrade at all, and if the actual media starts getting "rot" (as was the case from a few shops back in the 80's) then it is easy peasy to just rip it and back it up and reburn. Vinyl? Heh, no.
Is vinyl for everyone? No. It took me years of decision making before I finally went for it. I don't regret it, but I don't think that one needs a $$$$$$ system to get amazing sound out of an lp. The initial offering I had experience with ran about 200 USD tops and it was stellar.
Zanth is offline
Old 07-14-2005, 06:12 PM   #24 (permalink)
Moderator
Profile
Default
1) Having to get several copies of a record before finding one that didn't crackle or skip.
New vinyl may crackle/skip because of the dust in the grooves, one wet wash will clear this up. If not, then I guess yeah, returning it is necessary. Not like scratched digital media never happens though...I can't say to what rate this happens compared with that of vinyl though. So far, I have not had to return any of my vinyl and I have predominantly bought new. (in fact my used vinyl has sounded better!)
2) Remembering to turn the volume down on the amp so that the lead in/out procedure didn't blow your speakers and your ears.
I have not had this problem, maybe because I only use headphones? In all honesty though, I habitually decrease the volume with any new disc (cd or lp). The only time I don't is with mp3's, but I do have to attenuate various tracks as they are often recorded at different volumes.
3) Static.
I am just now beginning to experience this. Though there are folks who believe cd's build up static, I don't buy into it that much at all. LP's? Oh yeah, I need to buy a zerostat gun. Storing them in anti-static sleeves should help minimize this, and these sleeves are better for the records anyway (higher grade, plastic so no shedding or scratching etc).
4) Dust.
For sure, cleaning is the major downside to vinyl, but in my last post I addressed this. One wet wash and then a simple dry brushing before each play should be enough. Perhaps an annual wet wash? Not sure yet, I'll let you know in a year
5) Surface noise.
Clean vinyl = no surface noise. I know I have some clean vinyl here. Dead silent. Get a super quiet phono like a Samuels offering or the Dynavector P75 I am using and it is BLACK.
6) Distortion that increased towards the end of each side of the record.
I am not familiar with this, what do you mean by distortion?
7) Having to clean the records and stylus without damaging either.
Cleaning records is easy...the stylus, yeah care needs to be taken. Some like the wet brush, some like dry brushing with SAND PAPER!!!! I have a Zerodust blob of goop, a bit dangerous because of the downward force exherted. So far so good though, but yeah, if something goes wrong here, one neeeds a new stylus.
8) Having to replace the stylus every so often.
This is my single biggest beef. A well setup stylus should last at least 1000 hours. The problem is the investment. IF one really likes those 2k carts, and had to scrimp and save, is it worth 2k annually if one listens often enough? Tough call, I don't have that kind of cash, and perhaps I never will. However, there are certainly many fine carts that are under 300, so if one calculates it out...it isn't that expensive but still, I agree, a pain.
9) Remembering not to fall asleep and let the run out groove wear the stylus to a nub.
Yep this is not cool at all.
10) Having to learn juggling to get the record out of its sleeve onto the deck without scratching it, fingering it or dropping it.
I don't have that problem, maybe I have a high dexterity? Regardless, your points are all valid, some easily solved others never will be.
It ends up coming down to a decision, are the merits of hte sound benefits (a more natural and perhaps more resolving and dynamic experience) worth the efforts. For me yes, and I so love the convenience of 60 gigs on hand at all times, power up the iPod and just go for 10 straight hours of studying or programming or whatever. But at home, that 20 minute or less, cycle is really nice and involving and again, I love the sound.
Zanth is offline
Old 07-14-2005, 06:59 PM   #25 (permalink)
bln
1000+ Head-Fi'er
bln's Avatar
Profile
IM Contacts
Send a message via AIM to bln
Default
I don't see how the runout groove wears down the stylus any more than regular playing. Diamond is pretty tough. If you fall asleep, it's not the end of the world.
__________________
Harman Kardon T35 / Denon DL110 + Sony CDP-CE245 -- Kenwood KR6400 -- Avid 80s + Grado SR-60
bln is offline
Old 08-11-2005, 04:50 AM   #26 (permalink)
100+ Head-Fi'er
Profile
Default Idiot Doubt
I must say that i have never heard a vinyl setup :blink: and so I am not supposed to comment on it, but I kinda know that its an old standard that well outbeats the present day CDs
What I wanted to actually ask is, if and when the DVD audio comes out at 24bit processing, will the Vinyl still hold ground?
Cerebral_Mamba is offline
Old 08-11-2005, 04:01 PM   #27 (permalink)
Moderator
Profile
Default
Probably.
Zanth is offline
Old 08-12-2005, 02:47 AM   #28 (permalink)
cpw
Contributor
500+ Member:
cpw's Avatar
Profile
Default
Here's my $.02 though my experience w/ high end vinyl is limited:
Get at least an MMF-5 and if you go up from there get a VPI Scout. You can certainly go up from there but you quickly reach a point of diminishing returns (I recognize that others may not agree here).
I think the phono stage is worth some investment. I have the Ray Samuels XR-2 and you could spend alot more money for less quality and sound. OTOH, a friend has a Radio Shack battery powered stage that actually sounded damn good and it's practically free. YMMV.
I've only tried about 5 carts. My least favorite was the Grado Platinum Reference. It was noisy w/ out lots of fiddling and though it sounded great on some material, it was not what I consider a good all around cart.
Dynavector (10X5) was very good but I finally settled on the lowly Blue Point Special EvoIII from Sumiko. It is cheap (so I won't shrink from replacing it when its time comes), deadly quiet and sounds great on every type of music I can throw at it.
I'm having great fun w/ vinyl even though it doesn't always sound better than CD. It's a way of life.
Todd is a great guide. He'll give you honest and competent advice. Whaddaya got to lose?
CPW
__________________
Headphoneus Ignoramus
Team Pinnner
Team Covert Upgrade
Team: "I'm in it for the pushups."
cpw is offline
Old 08-17-2005, 10:24 PM   #29 (permalink)
100+ Head-Fi'er
Profile
Default
Not.
Vinyl is an anachronism designed by Satan to taunt audiophiles all over the planet.
He promises fidelity of sound (but only if you can't tell when the sound is being coloured by harmonic distortion).
That newfangled digital technology seems promising......
:allteeth:
Well... I have to tell you that I am a vinyl enthusiast too, but , I don't think vinyl sounds better than CD - it just sounds different .
Maybe it's because that its dynamic range is considerably smaller than CD that voices are produced so magically and instruments sound lifelike, and maybe it's because of its higher background distortion and noise that makes detail more audible ( this is no joke ).
I agree that there are many downsides to vinyl, but every time I get enchanted by a record's sound all those downsides are forgotten :600smile: .
Axel is offline
Old 04-07-2008, 11:23 PM   #30 (permalink)
500+ Head-Fi'er
JMcMasterJ's Avatar
Profile
Default
I know I'm digging up an old thread, but I'm soo tempted to get into vinyl. I love playing my parent's old records when I go over to their house. I just don't know if my wallet will be able to handle it. I would like to get something like a VPI Scout, but then there are so many other costs... cartridge, phono pre-amp, cleaning stuff, dust cover, etc. To vinyl or not to vinyl? hmmm....
__________________
Feedback
JMcMasterJ is offline
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by vBulletin® Version 3.6.8
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.1.0 Head-Fi.org
