You are in TTVJ's Premier Sponsor Forum at Head-Fi.org.
To get back to Head-Fi.org's Main Forums, click here.
Register FAQ Members List Calendar Mark Forums Read Today's Posts Search
Go Back   Head-Fi: Covering Headphones, Earphones and Portable Audio > Premier Sponsor Forums and Sponsor Forums > TTVJ Premier Sponsor Forum
TTVJ Premier Sponsor Forum TTV(&H)J Forum, and TTV(&H)J Announcements
Reply
Thread Tools Display Modes
Old 06-17-2005, 12:44 AM   #21 (permalink)
Mr.Radar's Avatar
Profile
Default
Hey lcrim, would you consider doing a review of your modded Technics compared to your P3 w/ SME? I'd be very interested in it (especially if you swaped the cart off your P3/SME onto your Technics for some of the review to help rule that out). Also, when you say "full boat mods" do you mean you got the upgraded PSU, fuild dampener, modded Groovemaster, 78 speed capability, and the strobe disabler?
__________________
Chaintech AV-710 Setup Guide || Folding for Head-Fi since Aug '04!
Digital Rig: EMU 0404 -> Headsave Classic (HSA2 version) -> Beyerdynamic DT770 Pro/M-Audio BX8 speakers
Analog Rig: Technics SL-1600 MKII (w/ Ortofon OM20) -> Harmon Kardon 730 Receiver -> DT770 Pro/M-Audio BX8 speakers
Portable Rig: Rio Karma -> Koss PortaPro 2
Team IMHO || Team Full PM Inbox || Team Teen-Fi || Team Direct-Drive
Mr.Radar is offline
Old 06-17-2005, 07:23 PM   #22 (permalink)
Junior Head-Fi'er
Profile
Default
Mr. Radar:
Sorry that I took so long but I forgot about posting on this thread . While I'm not really a headphone guy I really like this site. There is an honest interest in sharing information about high quality, yet affordably priced equipment.
My KAB modded Technics 1200 MK II was actually Kevin Barrett's test mule that he was kind enough to sell me at a ridiculously cheap price. It has the tonearm fluid damper, the outboard power supply, the strobe disabler and the record clamp. The cartridge began as the Stanton/ KAB "Groovemaster" but its stylus was changed to a Pickering D4500S stylus. This is in a system with a modded Antique Sound Labs Mini Phono Pre Amplifier and an Audio Electronics Supply AE-3 preamp and a modded (by Vinnie Rossi) TEAC A-L700P digital amp driving Sonus Faber Concertino Homes. The cabling is nothing exotic, AQ CV4 speaker cable, Harmonic Technologies, Blue Jeans Cables interconnects, Volex power cables. Power treatment is with a Transcendent Sound Balanced Power Transformer (kit.) Room (acoustic) Treatment by Eighth Nerve. This system is very well damped, highly detailed and warm. The analog playback is best with small jazz ensembles and chamber music as there is a bit of constriction with very dynamic, complex orchestral passages. The fluid damping contributes to great tracking and lowered groove noise as well lowered surface noise. The sounstage is more deep than wide but detail retrieval is terrific. The Stones "Exile on Mainstreet" is a densely mixed record that the Technics always reveals some new facet that " I never heard that before."
The Rega is the older model Planar 3 which I also bought second hand. It had the SME Series III tonearm mounted and a low compliance cartridge (MC) that was wrong for this arm. The arm works best with a high compliance cart like the old Shure V15. Mr. Barrett was kind enoughto adjust this somewhat antique arm and we added back the anti-skating weight and pulley assembly but the fluid damping trough and reservoir had been discarded by the previous owner as setting such things up apparently annoyed him. I wish I could find these pieces and restore them but its been no go. When strobe tested this TT seems to be spot on with a new belt and it has the optional heavy acrylic platter. This setup is in all tube system based on a Decware Select (SET) and uses a (George) Wright Sound WPL11 Phono/Line Preamplifier. The cartridge is pretty much the twin of the one in the Technics. The Grovemaster body is an Integrated mount , you plug it in and twist a locking ring. The SME arm is a standard mount and I use a Pickering EP HiFi cartridge body w/Pickering D4500S stylus, this looks different than the Groovemaster but the coil, cantilever, pivot assembly etc. are virtually identical. You might get the idea that I like this particular MM cartridge. Its true, I think these pieces produce an excellent sound. If I had to compare them, remember they are in different (sized) rooms and very different ancillary gear. The Technics is like using a fine machine tool. You can reset things like vertical tracking angle with ease and quickly. The SME is like a fine antique that still works extremely well. The fact that it is missing the fluid damping probably tilts the field in favor of the Technics. There is a bit more groove noise w/ the Rega/SME and surface noise is a bit more noticeable as well. But it is now like an old friend that you forgive certain traits in because of affection. It has a familiarity and a known quality that gives me a baseline from which to make choices . The Technics is much smoother and ergonomic and pleasurable in a different way.
Sorry for the length but I get wound up when discussing analog.
lcrim is offline
Old 06-18-2005, 04:03 PM   #23 (permalink)
Mr.Radar's Avatar
Profile
Default
Thanks for your impressions lcrim! It sounds like you got a sweet deal there, I'm envious. I have one last question: how do you think the Technics does pop/rock music compared to your P3? Based on what I've read about the Technics, pop/rock should be its cut of tea, but I haven't read too much about pop/rock on other TTs. Again, thanks.
__________________
Mr.Radar is offline
Old 06-19-2005, 11:43 AM   #24 (permalink)
Junior Head-Fi'er
Profile
Default
I've never thought of the Technics as a strictly pop/rock TT. I think that it does jazz awfully well as that is the biggest part of my listening. The only valid criticism I can offer of the Technics is the tonearm wiring could be improved. Whether this is the cause of of compression on large orchestral crescendos or it is in the phono stage I can only speculate. As I am not a huge fan of orchestral music, it is not a big issue for me but somewhere down the line I am looking to improve the wiring.
lcrim is offline
Old 06-19-2005, 07:02 PM   #25 (permalink)
Mr.Radar's Avatar
Profile
Default
"Cup of tea" was probably the wrong choice of words. I meant that from what I've read the Technics should do pop and rock better than most other genres. Thanks for your insight again.
__________________
Mr.Radar is offline
Old 06-22-2005, 02:20 PM   #26 (permalink)
100+ Member
bhd812's Avatar
Profile
IM Contacts
Send a message via ICQ to bhd812 Send a message via AIM to bhd812 Send a message via Yahoo to bhd812
Default
Well two weeks back I think...
I went to record dug out store (located rite across the street where I host my headfi meets, also know as the touch of class..lol)
Mind you this was the first time I was ever in a record store..lol
first thing that hit me was the smell of old and stale paper, then of course the mass of records..
just all messy and stacked up on the floor and just all over.
I didnt know what to do, how and where do I start..lol???
I made a 10ft section in 2hours..lol and after I had a stack of records I decided to call it quits for the day.
then when I got home the two brand new duke ellingtons lps came in to, woot woot.
set up the rig and began listening..here are some quick impressions
the duke ellingtons 200gram brand new stuff was the same as what I get in my g08 really, just alittle more bass and presence.
the George Benson I picked up at the store was a dead on match to my g08 and the cd..
So I am thinking "What the hell?..I could of just stuck with the g08 and spent the money on speakers..lol)
thats until I put on a record I bought just for the cover it is Dean Martin's "Dream with Dean".
omg his voice!!!!!!!!!!!!
I knew Dean had a voice but omg on vinyl it comes out sooooooo damm good.
after that moment I am head over heals on vinyl now..lol
I think I might take my first drive up to beverly records today,,,got some money and some time,...why not
__________________
[center][color="SeaGreen"]
bhd812 is offline
Old 06-22-2005, 07:35 PM   #27 (permalink)
100+ Member
bhd812's Avatar
Profile
IM Contacts
Default
THANK YOU JOHNJCB
I went to Beverly records this mourning and ....
I didnt even make it past the Frank sinatra section!..I ran out of cash and burned the credit card to..lol
I love that place!!!!!!!!!!!1 :he90:
__________________
bhd812 is offline
Old 06-22-2005, 10:05 PM   #28 (permalink)
Contributor
100+ Member:
reynman con Clou.
reynman's Avatar
Profile
Default
Billy,
Nice stash! Have you settled on a record cleaner yet? I'm still waiting for my Sota Comet, but the XR2 is fully burned in!
Beverly is definitely on my list to check out.
__________________
DAPs - Sony 808, RH1, e507 Vaio Pocket (40g), a3000, 30G Zune
PMP - PSP and 32G iPod Touch
PCDP - Sony D25S Sony dej2000
IEM - Sensa 2X-S
Earbud - Yuin PK2
Headphone - Senn 650 w/Equinox cable
Headphone Amps - RSA SR71(6001 - numero uno!), RSA XP7, RSA Raptor
Analog - Sota Comet w/RB300 tonearn and Sumiko BPS EvoIII-RSA XR2 (phono stage)
Digital - Meridian 507 and modded NAD541
Sony NW HD1 (RIP)
reynman is offline
Old 06-23-2005, 12:46 AM   #29 (permalink)
100+ Head-Fi'er
djbnh's Avatar
Profile
Default
Try this site for tons more vinyl-related information:
http://www.vinylengine.com/
Excellent forums; free protractors/manuals/etc. Bon Appetit!
__________________
various sources including Rega P25, Sony D-33 and D5A, Jolida JD-100->RnB Audio Black Diamond Reference IC | Grover Huffman ICs->XIN SuperMacro-IV or NAD1240 preamp-> Stefan AudioArts Equinox Cable-Sennheiser HD650 | AKG K701 | Grado 325i | Koss KSC75.
My speakered home gear and dedicated listening room - Updated Pics
Feedback: Head-Fi; AudioGon; eBay
John 3:16; What's going on in Medjugorge? The latest Monthly Medjugorge message
"Love is patient, love is kind. It does not envy, it does not boast, it is not proud. It is not rude, it is not self-seeking. It is not easily angered, it keeps no record of wrongs. Love does not delight in evil, but rejoices with the truth. It always protects, always trusts, always hopes, always perseveres. Love never fails." I Corinthians 13:4-8
"All that is necessary for the triumph of evil is for good men to do nothing." Edmund Burke
djbnh is offline
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.2.0 Head-Fi.org
