You are in TTVJ's Premier Sponsor Forum at Head-Fi.org.
To get back to Head-Fi.org's Main Forums, click here.
Register FAQ Members List Calendar Mark Forums Read Today's Posts Search
Go Back   Head-Fi: Covering Headphones, Earphones and Portable Audio > Premier Sponsor Forums and Sponsor Forums > TTVJ Premier Sponsor Forum
TTVJ Premier Sponsor Forum TTV(&H)J Forum, and TTV(&H)J Announcements
Reply
Thread Tools Display Modes
Old 02-24-2006, 06:45 AM   #11 (permalink)
100+ Head-Fi'er
Kassem's Avatar
Profile
IM Contacts
Send a message via AIM to Kassem
Default
Well i found a couple places in my town that have stuff like.. hendrix, floyd, elton john, etc... mostly around 3-6$. Just seeing the used prices made me want to buy a system. Grr...
I just have one question.. and i havent been able to find a clear answer.
Is this a valid setup?
Thorens TD190 Turntable -> Marantz 1060 -> HD 600
If this is valid.. could someone also tell me what cables would connect between the Turntable and the 1060.
__________________
Proud Member of Team Fuzzy Fuzz's Fuzzbox
Home Setup: EMU-0404 modded by MisterX-> Marantz 1060-> Sennheiser HD600 w/ hd650 cable
Must... audition... Beyer DT880.. help
Feedback from head-fi members:
http://www6.head-fi.org/forums/showt...ghlight=Kassem
Kassem is offline
Old 02-24-2006, 03:14 PM   #12 (permalink)
Profile
Default
The Thorens will plug directly into the Moving Magnet phono input sockets on your Marantz 1060, there is no need for a phono stage as the amp has one already built in.
Not many Tonearms allow you to swop out the interconnects coming from the arm without a soldering iron so it's best to leave the current wiring intact as this can be very fiddly.
I havn't seen this turntable reviewed much but it's one of the few new ones at this price range which will play 78rpm. If you plan on delving that far back you might be lucky enough to find some old jazz records from the 30's and 40's which would need a special cartridge to play them which Thorens also supply for this deck.
By the looks of it it's unlikely to live upto the standards set by the classic Thorens like the TD150/160 but then again it's much cheaper in real terms.
Other decks to check out under 500USD are the Goldring GR1.2 or Rega Planar 2.
memepool is offline
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.6.8
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.1.0 Head-Fi.org
