You are in TTVJ's Premier Sponsor Forum at Head-Fi.org.
To get back to Head-Fi.org's Main Forums, click here.
Register FAQ Members List Calendar Mark Forums Read Today's Posts Search
Go Back   Head-Fi: Covering Headphones, Earphones and Portable Audio > Premier Sponsor Forums and Sponsor Forums > TTVJ Premier Sponsor Forum
TTVJ Premier Sponsor Forum TTV(&H)J Forum, and TTV(&H)J Announcements
Reply
Thread Tools Display Modes
Old 10-21-2004, 12:39 PM   #31 (permalink)
cpw
Contributor
500+ Member:
cpw's Avatar
Profile
Default
Originally Posted by marios_mar
so you still have not tried it with the new phono pre-amp
No, I have been using it w/ the XR2 for some weeks but I made a cable change shortly after that and I think it was a bad one.
A subwoofer went into the system yesterday and the SACDmods 963 later this week. This system has been constantly moving but should start to settle down once the Stealth is here and evrything is properly cabled in. Then I'll start to fine tune things a bit. Right now it's too much of a moving target.
CPW
__________________
Headphoneus Ignoramus
Team Pinnner
Team Covert Upgrade
Team: "I'm in it for the pushups."
cpw is offline
Old 10-23-2004, 04:04 AM   #32 (permalink)
cpw
Contributor
500+ Member:
cpw's Avatar
Profile
Default
[quote=marios_mar]cpw
1. Did the 963 come back yet? Will you give us impressions?
See the source forum.
CPW
__________________
Team Pinnner
Team Covert Upgrade
cpw is offline
Old 10-23-2004, 08:16 AM   #33 (permalink)
marios_mar's Avatar
Profile
Default
i will right now.
marios_mar is offline
Old 10-23-2004, 09:05 AM   #34 (permalink)
marios_mar's Avatar
Profile
Default
i saw it.
thanks.
can't wait till you use your new phono stage and do a comparison using some great recording on some nice vinyl pressing vs the redbood version.
Old 10-25-2004, 01:08 PM   #35 (permalink)
500+ Head-Fi'er
Profile
Default
Originally Posted by cpw
[html] The Scout tone arm is more susceptible to vibrations from my floor but part of that may be the new Solus rack as well.
The best solution to this I've found is to mount the record player to the wall.
It can be made to look like it is on a rack, but if mounted on a load bearing wall it will be very solid.
dknightd is offline
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.6.8
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.1.0 Head-Fi.org
