You are in TTVJ's Premier Sponsor Forum at Head-Fi.org.
To get back to Head-Fi.org's Main Forums, click here.
Register FAQ Members List Calendar Mark Forums Read Today's Posts Search
Go Back   Head-Fi: Covering Headphones, Earphones and Portable Audio > Premier Sponsor Forums and Sponsor Forums > TTVJ Premier Sponsor Forum
TTVJ Premier Sponsor Forum TTV(&H)J Forum, and TTV(&H)J Announcements
Reply
Thread Tools Display Modes
Old 11-04-2003, 03:48 PM   #21 (permalink)
500+ Head-Fi'er
mariowar's Avatar
Profile
Default
John, have you tested the amp using different headphones?
Dimitri, did you get your Plainviews from www.thomasdistributing.com? it says the are 9.6 volts, which it means that they are even better than regular alkalines (9 volts)??
See it's strange if you get AA nimh you can only get 1.2 volts instead of 1.5 volts (regular alkalines).........
I hope the plainviews will last as long as regular alkaline batteries. What I plan to do is to charge them every week...it would be more than enough. Keep in mind that they (NIMH) lose about 3% of the charge everyday even if they are not in use.
mariowar is offline
Old 11-04-2003, 04:05 PM   #22 (permalink)
Moderator
This is a customized witticism.
john_jcb's Avatar
Profile
Default
I have listened to the XP-7 with a few different ones; HD-600 w/Cardas, Grado RS-1 & SR225, Sony MDR-CD3000; AKG: 401; Koss: Porta Pro and Etymotic 4S. It really does a great job with all of them. Ray used the HD-600, RS-1 and MDR-CD3000's to listen during the development phase to insure that the amp worked well with all different levels of headphone impedences.
__________________
John
Music washes away from the soul the dust of everyday life. --Red Auerbach
john_jcb is offline
Old 11-04-2003, 04:29 PM   #23 (permalink)
500+ Head-Fi'er
mariowar's Avatar
Profile
Default
Well, I have the HD 590 ( 120 ohms) and I'm waiting for the Equinox cable......I'll post my impressions soon...
mariowar is offline
Old 11-04-2003, 06:51 PM   #24 (permalink)
Head-Fi'er
Dimitri's Avatar
Profile
Default
Hi mariowar,
Yes, I did get my Plainviews from Thomas Dist. I bought two overnight chargers from them as well. They claim that common alkaline 9 volt batteries never charge fully, reaching only 8.4 volts or so. Headfi members seemed to like Plainview NiMH batteries and I bought them mainly for this reason. I havn't had the amp long enough to judge battery life, but I have read claims of 30+ hrs with rechargeables.
Cheers
__________________
Sources: Sony NS500V SA-CD, Optimus 3420 PCDP, 4gb nano
Amp: Ray Samuels XP-7 w/AD797 op-amps
Headphones: Sennheiser HD650 w/ Zu Mobius Cable, Sennheiser HD280, Koss Porta Pro; had Grado SR-325, Etymotic ER6i
Dimitri is offline
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.2.0 Head-Fi.org
