Head-Fi: Covering Headphones, Earphones and Portable Audio
Support Head-Fi by starting your Amazon.com shopping by clicking here
Follow headfi on Twitter!
Follow Rocky Mountain Audiofest (RMAF) on Twitter!
Head-Fi Is Sponsored By:
Featured
Head-Fi's Sponsors
(Premier Sponsors bolded)
Featured
Can Jam '09
(2009 International
Head-Fi Meet)
Impressions,
Reviews, Photos
Can Jam '09 graphic
courtesy of Edwood
Click on the links below
for Can Jam '09 photos,
impressions and reviews:
blubliss 1, 2, 3
dallan 1, 2, 3, 4
santacore 1, 2
nhat_thanh 1, 2
vpivinylspinner 1, 2, 3
amb 1
augustwest 1
eaglejo 1
johnsonad 1
shellylh 1
Jon L 1, 2, 3, 4
Germancub 1
zippy2001 1
IPodPJ 1
bhd812 1
Edwood 1, 2
abellaw 1, 2
minidiscs 1
atothex 1
HighLife 1
achristilaw 1
SiBurning 1, 2, 3, 4
SiBurning 5, 6, 7
LFF 1
Iron_Dreamer 1
doping panda 1
morphsci 1
ironbut 1
shaizada 1
jasper994 1, 2
jp11801 1
Uncle Erik 1
drubrew 1
(More impressions/photos
still being added.)
Head-Fi Blogs
and Facebook
Check out Head-Fi's new
Blogs section.
Featured Head-Fi Blogs:
Jude's "Take My Word"
 From Japan - by Sasaki
Currawong's Blog
Start your own Blog!)
Attention
Facebook Users
Join the official
Head-Fi.org
Facebook Group
Featured
Head-Fi's Sponsors
Featured
  #676 (permalink)
Old 04-10-2008, 11:27 PM
chesebert's Avatar
Default
Originally Posted by bigshot View Post
That sounds like inverted phase to me.
See ya
Steve
nope..wrong.
__________________
TEAM HF-1(#25) / HF-2 (#268) TEAM HSPICE
Headfi Feedback
Headphone: SB3/CAL Delta > Corda Opera/M^3 > HD650v2; HF-1; HF-2
Speaker: SD Transporter > CAL Alpha > Ayre AX-7e > Harbeth Monitor 30
  #677 (permalink)
Old 04-11-2008, 12:52 AM
Budgie's Avatar
500+ Member:
Never looks a gift amp in the jackhole.
Default
The Radio Shack sound meters have very questionable accuracy at low frequencies.
StereoTimes -- Useful Modifications to the RadioShack Analog SPL Meter
I don't think it got any better with the new digital readout version.
That said, one would think the inaccuracy would at least be repeatable.
  #678 (permalink)
Old 04-11-2008, 01:05 AM
Jam_Master_J's Avatar
Send a message via MSN to Jam_Master_J
Default
I think a better test would be to use an oscilloscope on the speaker output terminals with speakers still connected (this would ensure the amp is acting as it would under load). Then sweep frequencies, or feed it some white noise and take the FFT (frequency domain) capture of the output. If one power cord was affecting the frequency response, it should be visible in this case. 2dB would be quite noticeable too.
__________________
My Feedback
  #679 (permalink)
Old 04-11-2008, 01:41 AM
chesebert's Avatar
Default
yes that would be a better test; not a lab test but should be more accurate than than the radioshack sound meter.
__________________
Headfi Feedback
  #680 (permalink)
Old 04-11-2008, 03:22 AM
gilency's Avatar
1000+ Head-Fi'er
Default
get a virtual dog
  #681 (permalink)
Old 04-11-2008, 04:26 AM
Pars's Avatar
Can Jam '10 Organizer
Default
See ya
Steve
Originally Posted by furball View Post
All very good ideas guys!
This is a power cable he is talking about... don't think you can invert the phase on single phase AC...
  #682 (permalink)
Old 04-11-2008, 04:26 PM
Wolffy's Avatar
Junior Head-Fi'er
Default Probably means reversed polarity.
You are correct in that most of the power is single phase coming out of residential homes. Unless you have commercial or heavy duty equipment that can utilize dual phase.
Reversing the polarity of a power cord might have a sonic impact depending on the sensitivity of the component.
Michael
  #683 (permalink)
Old 04-11-2008, 05:55 PM
bigshot's Avatar
Default
Yow!
See ya
Steve
  #684 (permalink)
Old 04-11-2008, 06:47 PM
dvw dvw is offline
100+ Head-Fi'er
Default
It would be a much better test. All you need to do is to feed a 30Hz signal. 2dB is about 1.6 difference in amplitude. It would definitely be noticeable.
  #685 (permalink)
Old 04-14-2008, 04:59 PM
100+ Head-Fi'er
Default
Why not just test the power cord on the PSU? A PSU will convert the AC power to DC. Why not just measure the effect of changing power cords with the PSU DC output. If you get pure DC output with both cables, it stands to reason that power cords make no difference.
  #686 (permalink)
Old 04-16-2008, 05:31 PM
500+ Head-Fi'er
Send a message via MSN to Maniac
Default
If that route is going to be taken then, it begs the question of how and what to test on a PSU. IIRC, there's a whole pile of tests that can be done on PSUs, and I don't think they are any less complicated than testing audio stuff.
__________________
Currently applying for Member of Trade status...
Feedback Thread: http://www.head-fi.org/forums/f12/maniac-329127
The creator of UberShipSpeed, ExtremeNeutralToneExpansionResonancePerformanceRev ealIsolationSystemEnhancement. (USS-ENTERPRISE)
(love that string of meaningless acronyms...)
  #687 (permalink)
Old 04-16-2008, 06:21 PM
100+ Head-Fi'er
Default
There are also an infinite number of tests for audio equipment as you have an infinite range of frequencies. As well, you have more equipment in the system.
All I want to see is if the output from the PSU stays the same. It is DC power, so if there is any noise that gets eliminated or added with either cord, you have a base for saying power cords can make a difference.
If the PSU works ideally and is stable for both cables (as it theoretically should), there are a lot of people on this site that can save quite a bit of money.
This is way more reliable than testing audio equipment because there are fewer components that could add error. When performing tests, it's important to eliminate as many variables as possible to promote accurate results. It would also help us determine exactly what is happening.
For example, perhaps a PSU is letting a certain frequency through that is eliminated with the use of an expensive power cord. It would likely be cheaper to simply add a filter to correct this problem then spending thousands on wire.
  #688 (permalink)
Old 04-16-2008, 06:35 PM
500+ Head-Fi'er
Default
There's also an almost infinite amount of condition and load situation that you can put a PSU through. Are you going to measure it at idle? at 50% load? at 100% load? at 120% in short bursts? or are you going to load it with a load that changes all the time very rapidly?
IMHO it isn't really making it simpler, it is just as complicated and the result may not directly referencing to what would be happening when you hook it onto audio equipments. Not to mention that noise is not the only measure of performance for audio equipments.
But personally speaking, I'd say that noises in the recording is what really annoying me. I once heard that 120Hz buzzing in a commercially released CD that just totally p*ssed me off. Power cable may help, but not to a dramatic degree of a bad recording vs good recording. However, a rather polluting switching power can come close if it is plugged into the wrong spot. I have used a few very nice sounding switching PSU on my own DIY projects, they sound clean, fast and very transparent... but they will make other equipments sound muddy and artificial if they share an AC outlet or are wired too closely...
__________________
  #689 (permalink)
Old 04-16-2008, 06:50 PM
100+ Head-Fi'er
Default
I thought it was clear that my noise example was only an example... obviously it is not the only issue....
The point that I am trying to make is that any improvement found by a 'magic' power cord could likely be done cheaper on the PSU. If your PSU is very very good, the cord should not matter at all as long as it is proper gauge.
  #690 (permalink)
Old 04-16-2008, 06:58 PM
500+ Head-Fi'er
Default
Well, in theory true, and like I said before, what are you going to test? There are just as many things that can be tested on PSU as in audio. How do you determine what's going to affect the resulting sound? Number don't really mean much if it didn't reflect what's being heard.
For example would be my CD Player, a Sony CDP-X5000. It have some of the best power supply setup that I've ever seen stuffed into such a small case. Large snap-in caps (looks like custom Silmic from Elna) and all kind of regulator circuit. there are even some OP controlled regulators in there as well.
But guess what? It is also one of the more sensitive equipments in my setup to different power cords, even tho I'm only using its digital output only.
I have no idea why it's affected like that, and it goes against all the electrical/electronics knowledge I have learned so far. However, it is always fun to find out stuff like that tho.
__________________
Closed Thread
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.3.2
Head-Fi.org
