| Cables, Power, Tweaks, Speakers, Accessories (DBT-Free Forum) Discussion of cables, power (the electric kind), tweaks, & accessories. |
09-29-2007, 03:41 PM
Headphoneus Supremus: DarkAngel's a man, baby!
I have entire drawer of footer tweaks, have tried many designs over last 20 yrs. For the Myrtle blocks they should contact gear case not under existing feet, I would use only 3 since weight support not an issue and this gives you even stable mount platform.
There is guy at Audiogon tweak section that makes/sells his own Myrtle blocks for cheaper price........without the Cardas logo.
Personally I do not use the Myrtle blocks in my systems, but they are simple and easy. I currently use Herbies 1" Tenderfeet and Isocup footers and Mapleshade Brass cones with Maple platforms.
In the past I found the bearing designs like Aurios and Rollerblock very effective buy a real hassle and heavy cables can mess them up, so to simplify I quit using them.
09-29-2007, 05:20 PM
Headphoneus Supremus Member of the Trade: S² Audio
Location: I'm a displaced Alaskan living at the beach in Port Aransas, Texas.
Originally Posted by nick20
How much did you pay for the pod/cone combo?
The myrtle wood blocks are about $7 a block, which isn't very expensive, of course you have to buy 6, which allows you to use 3 per component, but nonetheless, $7 a piece is very in-expensive IMO.
I have also seen the cork/rubber blocks you mentioned too.. I think I'll pick up these instead:
http://www.dedicatedaudio.com/inc/sdetail/2650
and maybe the Cardas blocks, and see what difference I can tell, if any.
I think I paid $12.00 per pod/cone (so that would be $36.00 per component if three are used). I misunderstood the price of the Myrtle blocks, and agree that $7.00 per block is quite reasonable, especially given the nice aesthetics of the finished product.
The article from Stereophile was interesting too, and has me wanting to try some Myrtle blocks myself.
09-29-2007, 08:42 PM
I would not use cardas block unless you have a good rack; cardas block transmits vibrations both ways, so bad rack means vibration up into the component; and that just defeats the purpose of the block.
__________________
TEAM HF-1(#25) / HF-2 (#268) TEAM HSPICE
Headfi Feedback
Headphone: SB3/CAL Delta > Corda Opera/M^3 > HD650v2; HF-1; HF-2
Speaker: SD Transporter > CAL Alpha > Ayre AX-7e > Harbeth Monitor 30
09-30-2007, 08:00 AM
vcoheda, have you placed the Apache on top of the Meridian, or next to it? I've read reports that weighting down CD players can be just as effective a vibration isolation method as isolator feet or blocks, was wondering if you've tried it. Heavy books can work if the Apache isn't heavy enough, they seem to be a common method.
10-01-2007, 05:48 AM
Headphoneus Supremus: High-End Forum Volunteer
my apache power supply and amp sit atop my G08 - maybe that is isolation in itself. i tried the cardas blocks under the G08 with and without the apache components on top. couldn't detect any difference.
__________________
1. Cary 306 SACD »» RSA B52 or HR Bal Home »» HD650 / HD800
2. Cary 306 SACD »» HEV70 »» HE60
FS: HF2 (#49) / RS1 / SR325 Click Here
SPRING NYC HEAD-FI MEET (MAR 13) Click Here
Head-fi
10-02-2007, 01:05 AM
Hrmm, I guess the Meridian is already optimally designed to counter vibration then. Interesting to learn that the blocks had the most effect under the Apache's PSU, I guess there really is some credit to the theory that stabilizing power transformers can result in better sound.
10-12-2007, 09:01 PM
EDIT: i was wrong about the G08. the bottom is covered in a different kind of material than the top, but it is not rubber. it is hard kind of plastic. only the corners have the rubber protrusions. also, i experimented more with the blocks and actually do think they make a subtle difference under the G08 - but i noticed that placement is key. before i was using two blocks in back an one front. after playing around with the player, it is clear that the front end is heavier than the back end. so i now use two blocks up front and one back and i think this combination has a beneficial effect - although it is not as apparent as using the blocks under the Apache power supply. to be safe, it is probably easier to use four blocks under all pieces of equipment. i may buy some more just for this purpose.
__________________
Head-fi
10-12-2007, 09:58 PM
Banned
Originally Posted by vcoheda
i tried the cardas blocks again under my Meridian G08 and did not notice any difference. i found this odd, because site after site people recommend using isolation components under the CD player, because of a noticeable effect. however, when i was taking another look at the G08, i noticed that the entire bottom is covered in a layer of rubber material which then protrudes at the corners to form feet. i think this is the reason the blocks do not work - i.e., there is already isolation there.
not sure why i didn't notice this before, but it is a semi-heavy player and i do not find myself lifting it up at such an angle as to see clearly the entire bottom half. from what i have read and my experience with them under my Apache, i do think it is likely that the cardas blocks will have a positive effect on other CD players.
I went ahead and ordered a 6-pack of the small blocks.
I think your CDP's of much better quality, right? And probably uses better isolation/dampening material.
My next cheap "tweak" is going to be add some Dynamat dampening material inside my CDP, because of some vibrations I can feel with my hand applying pressure to the CD tray. I found some of these stuff for $12 online, and retails for $40 in stores.
-Nick
10-16-2007, 10:22 PM
500+ Head-Fi'er
i've had really excellent results with my myrtle blocks under all compenents that are in the speaker/hi-fi chain, except my TT - i prefer my FIM iso-bearings. i have a Salamander rack with shelves made of mdf. the blocks clean up the bass quite a bit, including overall speed and transient detail throughout the other registers - the music just flows better.
these tweaks fall in the YMMV category. the myrtle blocks are cheap enough to suck it and see. an excellent VFM tweak in my hi-fi.
PACE
__________________
oppo DV-980H / gamma2 / benchmark DAC1
b22 / bijou / m3 / mini3
dt990-600ohm / akg k271 mk ii
stereovox XV2
supra EFF1-eichmann / cotton silver-furutech / chord co. Chrysalis-neutrik Pro-Fi / cardas hook-up wire-switchcraft
vh audio Flavor1+2
10-17-2007, 02:12 AM
100+ Head-Fi'er
Silly question for Myrtle block users.
How are you supposed to orientate the blocks under the equipment? Is it with the Cardas logo facing upwards or facing forwards?
Thanks.
10-17-2007, 02:17 AM
Banned
Originally Posted by Tbln
Questions for Myrtle block users.
Good question. I just received my 6 blocks today, and had the same question.
I don't think there is a right or wrong answer however, you may want to experiment with them.
This is how I have them; and this is also what I was told was the "proper" way.
"The Cardas logo facing you..."
Hope this helps..
-Nick
10-17-2007, 02:45 AM
the logo (i believe) serves two purposes - one is decorative and the second (more importantly) is to mark the alignment of the wood. i read that when using wooden isolation blocks, the grain of the wood should all run in the same direction.
also, if you using 3 blocks, you will use a pyramid formation - 2 in the back and 1 in the front. this formation could be reversed depending on the where the weight of the component falls - the heavier part is where the 2 blocks should be.
__________________
Head-fi
10-17-2007, 04:18 AM
500+ Head-Fi'er
mine are the lower right with a single notch. Cardas makes these for Ayre with their own logo. the notch is to lift/secure cables if one so chooses to use these for that purpose - i do not.
per the dealer i bought them from, it doesn't matter which way they are oriented, just make sure that you are consistant with orientation, and place 2 of them under the heavier side of the component.
PACE
__________________
stereovox XV2
vh audio Flavor1+2
10-17-2007, 04:20 AM
Banned
PACE
Just out of curiosity, these are the same price as the Cardas blocks, correct? From the places I found both the Ayre and Cardas blocks, they were consistent with pricing.
Is that true on your end? Mind me asking how much you paid for yours?
-Nick
10-17-2007, 04:31 AM
500+ Head-Fi'er
-Nick
i think i paid $7 or $7.50 a piece + tax.
the dealer i bought them from swears by these blocks and sells mdf Salamander and Sanus racks, placing them under every piece of electronics. they really work well with my Salamander rack.
PACE
__________________
stereovox XV2
vh audio Flavor1+2
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
Head-Fi's Sponsors
(Premier Sponsors bolded) |
Head-Fi Blogs
and Facebook |
Head-Fi's Sponsors
