Support Head-Fi.org by starting all of your Amazon.com shopping by clicking here.
____________________________________________________________________
Today's Featured Head-Fi Blog:  Jude's Blog
Please help support Head-Fi by becoming a Contributing Member  CLICK HERE
-- Contributing Members, thank you for your generous support! --
Head-Fi Is Sponsored By:
Register FAQ Blogs Members List Calendar Mark Forums Read Today's Posts Search
Head-Fi's Sponsors
(Premier Sponsors bolded)
Featured
2008 International
Head-Fi Meet
(Can Jam '08)
Impressions,
Reviews, Photos
Can Jam '08 graphic
courtesy of Edwood
Click on the links below
for Can Jam '08 photos,
impressions and reviews:
NightWoundsTime
lan
agile_one
wavoman
crappyjones123
Luke G
bperboy
jimaxp
Can Jam '08 Logo
T-Shirts For Sale
Head-Fi Blogs
and Facebook
Check out Head-Fi's new
Blogs section.
Featured Head-Fi Blogs:
Jude's "Take My Word"
 From Japan - by Sasaki
 LFF's Blog
Start your own Blog!)
Attention
Facebook Users
Join the official
Head-Fi.org
Facebook Group
Head-Fi's Sponsors
Featured
Go Back   Head-Fi: Covering Headphones, Earphones and Portable Audio > Equipment Forums > Portable Source Gear
Portable Source Gear Discussion of portable audio source gear, like iPods, other digital audio players (DAPs), MD players, portable CD players.
Meier Audio CORDA HEADSIX & The Most Recent Sponsored Threads
Celebrating 6 years of Head-Fi, Meier Audio introduces the Limited Edition HEADSIX (portable headphone amp) Head-Fi Support Sales Action
Reply
Thread Tools Display Modes
Old 04-22-2008, 11:30 AM   #11 (permalink)
Junior Head-Fi'er
Profile
Default
AFAIK AVLS is just a volume limiter which can be turned on or off.
Chase- is offline
Old 04-23-2008, 06:39 AM   #12 (permalink)
100+ Head-Fi'er
Profile
Default
have you guys played around with the DAC settings in the test menu? I've played around with it and you can adjust bass but not very indepth. the treble gain does practically nothing. but if you set the bass fc to 0.0 and the khz to 250 i get some pretty nice bass than before. anyone care to explain what these things are? the setting made the difference between the bass being a bop to a boom.
edit: for the record the test menu works for A81x models. to access it, go to the home screen, slide up hold, HOLD THE OPTION BUTTON AND PRESS THE FOLLOWING IN THIS ORDER: up, up, down, down, right, left, up, down, up, down, right, play/pause. let go and it should shut your walkman off. slide the hold switch off and it shoudl turn on and it'll take a few seconds then you'll reach a color test screen. after that explore in DAC. play aroudn adn tell me what you guys make of it.
silverknit3 is offline
Old 04-23-2008, 07:05 AM   #13 (permalink)
shigzeo's Avatar
Profile
IM Contacts
Send a message via MSN to shigzeo
Default
i onlly wish thee were a way to change between drag and drop and sonic stage, would love to use this without booting up into windows. but... at the same time, i love the recording functions of my 600 series.
600 is also the same series of buttons to enact hardware mode
__________________
BOSE: Better Sound Through Research
So, You Think You're Hot: Headfi Edition
shigzeo is offline
Old 04-23-2008, 05:14 PM   #14 (permalink)
100+ Head-Fi'er
Profile
Default
I just fumbled around with the test menu. In fact, I noticed that DAC treble gain actually changes the sound. I really like bright sound and my EQ is very brightly-tuned, but I had problems with sibilance with many tracks. So, what I did was try different FCs, and 10KHz(Gain: +1.5db) seems to lower the sibilance, as it increases only the frequencies above. Now I can lower some of the bars in the EQ and I get basically the same sound, minus the sibilance(not 100% less, but lets say 60%). Btw, 1KHz test tone @ 25 volume is really a pain in the... ears. (20Hz is kinda cool though, as well as 20KHz)
toxicsweet is offline
Old 04-24-2008, 12:48 AM   #15 (permalink)
Head-Fi'er
wolfboy's Avatar
Profile
Default
Is there any way of replacing Rhapshody with the Clock like in the A818?
wolfboy is offline
Old 04-27-2008, 02:47 AM   #16 (permalink)
100+ Head-Fi'er
Profile
Default
i played with the treble settings too. its impossible to listen to it with the fc at 0. i felt as if it was too hissy. have you played with the bass settings? they noticeably reduce the if you lower the bass fc from anythign besides 0. Does anyone know what fc stands for?
Old 04-27-2008, 02:59 AM   #17 (permalink)
100+ Head-Fi'er:
Member of the Trade:
RH Customs
Profile
IM Contacts
Send a message via AIM to TheRH Send a message via MSN to TheRH Send a message via Yahoo to TheRH
Default
Will this work on the 600 series?
__________________
Yes, but mine goes to eleven.
My Feedback http://www.head-fi.org/forums/f12/therh-286773/
TheRH is offline
Old 04-27-2008, 09:58 AM   #18 (permalink)
100+ Head-Fi'er
Profile
Default
Treble FC can't be 0, look again. The db can be 0/1.5, and FC can be 5,7,10,15kHz. FC means frequency cut(the lowest frequency threshold of the treble gain). On the other side, FC of the bass gain is the highest frequency which will be amplified.
So, my setup is:
DAC BASS GAIN
0.0
DAC BASS FC
100Hz
DAC TREBLE GAIN
1.5
DAC TREBLE FC
10KHz
That pretty much solves the sibilance problem, and adds plenty of bass too. Thats with the stock headphones, so YMMV.
Old 04-27-2008, 10:34 PM   #19 (permalink)
100+ Head-Fi'er
Profile
Default
ahha thank you forpointing that out. i kept imagining in my head the gain and fc options switched. the treble fc at 1.5khz changes the sound and reduces the sibiliance, i tried your set up with shure SE210's but it sounded as if the bass wasnt as dragged on. changing the fc to 250khz changes the sound and makes it more bodied in my opinion. what are your takes on it? oh and if you're interested in overly exaggerated bass from the stock headphones tell me and ill post a DIY (;
also: if you use a custom EQ whats your settings?
Old 04-27-2008, 10:58 PM   #20 (permalink)
1UP
500+ Head-Fi'er
1UP's Avatar
Profile
Default
How would these settings be any different from what you can do via the EQ menu?
__________________
Gearless and hating it
1UP is offline
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.2.0 Head-Fi.org
