Head-Fi: Covering Headphones, Earphones and Portable Audio
Support Head-Fi by starting your Amazon.com shopping by clicking here
Follow headfi on Twitter!
Follow Rocky Mountain Audiofest (RMAF) on Twitter!
Head-Fi Is Sponsored By:
Featured
Head-Fi's Sponsors
(Premier Sponsors bolded)
Featured
Can Jam '09
(2009 International
Head-Fi Meet)
Impressions,
Reviews, Photos
Can Jam '09 graphic
courtesy of Edwood
Click on the links below
for Can Jam '09 photos,
impressions and reviews:
blubliss 1, 2, 3
dallan 1, 2, 3, 4
santacore 1, 2
nhat_thanh 1, 2
vpivinylspinner 1, 2, 3
amb 1
augustwest 1
eaglejo 1
johnsonad 1
shellylh 1
Jon L 1, 2, 3, 4
Germancub 1
zippy2001 1
IPodPJ 1
bhd812 1
Edwood 1, 2
abellaw 1, 2
minidiscs 1
atothex 1
HighLife 1
achristilaw 1
SiBurning 1, 2, 3, 4
SiBurning 5, 6, 7
LFF 1
Iron_Dreamer 1
doping panda 1
morphsci 1
ironbut 1
shaizada 1
jasper994 1, 2
jp11801 1
Uncle Erik 1
drubrew 1
(More impressions/photos
still being added.)
Head-Fi Blogs
and Facebook
Check out Head-Fi's new
Blogs section.
Featured Head-Fi Blogs:
Jude's "Take My Word"
 From Japan - by Sasaki
Currawong's Blog
Start your own Blog!)
Attention
Facebook Users
Join the official
Head-Fi.org
Facebook Group
Featured
Head-Fi's Sponsors
Featured
  #16 (permalink)
Old 01-20-2008, 06:37 PM
1000+ Head-Fi'er
Default
Originally Posted by serpico View Post
I would just exchange it for another just to make sure it's not the device. If you get the same problem with the new one, then it's probably a defect in the series. Maybe a flash model is better or just another brand.
Its definitely the 1.1 update causing this problem. I haven't experienced such problems prior to the latest update.
  #17 (permalink)
Old 01-20-2008, 07:45 PM
Clutz's Avatar
Headphoneus Supremus:
Tells us when we're offset.
Default
I just measured the DC offset on my 80GB iPod Classic. I only found DC offset on one of the two channels, and while it was alarmingly high (ranged between about 30mV-80mV), I didn't measure it as high as 0.5V.
Cheers,
Brad
  #18 (permalink)
Old 01-20-2008, 08:02 PM
Clutz's Avatar
Default
I've also noticed that there is significant DC offset even while music is playing. I don't think I will be using any of my good headphones with this iPod until they fix this issue with the DC offset!
  #19 (permalink)
Old 01-20-2008, 08:13 PM
me7 me7 is offline
Head-Fi'er
Default
How dangerous is this for headphones
__________________
iPod touch 3G 64GB
Shure SE310
  #20 (permalink)
Old 01-20-2008, 08:16 PM
J.D.N's Avatar
500+ Head-Fi'er
Default
Im really glad i haven't upgraded the firmware. Ill stay put till they sort it out!
Interestingly there isnt any talk of this over at Mac Rumors. I did mention it in a thread, but nothing.
Is anyone having issues with the LOD? Apparently that might be yet an another issue of the 1.1 upgrade. (I mean worse than the pausing/skipping discussed in the other thread)
__________________
Portable:iPod Classic 160Gb > UE Triple/Fi 10 Pro > ATH-ESW9
Home:Pro-Ject Xpression Mk3 > Naim CD5i > Naim NAC122x > Naim NAP150x > Mission M71i > DIY Floor Standers | Shanling PH100 > DT990
Other Stuff:MacBookPro | Nikon D40x > 18-200VR | LG Viewty
FEEDBACK
  #21 (permalink)
Old 01-20-2008, 08:17 PM
Clutz's Avatar
Default
It's quite dangerous. It could cause permanent damage. When building a headphone amp, you generally wouldn't connect your headphones to the headphone amp unless it had less than 10mV of DC offset - and I usually wait until I have less than 1mV if I'm able to get there. 80mV is a lot. 500mV (0.5V) is really a lot.
  #22 (permalink)
Old 01-20-2008, 08:28 PM
me7 me7 is offline
Head-Fi'er
Default
Can i measure this myself with my cheap on-board audio in?
EDIT: Is there a way to downgrade a iPod? iTunes does not offer an option for that.
__________________
iPod touch 3G 64GB
Shure SE310
  #23 (permalink)
Old 01-20-2008, 08:31 PM
Clutz's Avatar
Default
No, I don't think so. You would either need to have a voltmeter or a scope. Volt meters are pretty cheap though - you can get one at Radioshack for about $10. It wouldn't be a great one, but it would let you measure the voltage output.
  #24 (permalink)
Old 01-20-2008, 09:21 PM
me7 me7 is offline
Head-Fi'er
Default
I found an easy way to downgrade my iPod classic. First "Open iTunes and in Preferences uncheck automatic check for updates".
If you are a mac user, read here. Windows users need a different folder. Open "Documents and Settings", search the folder that represents your username and open the hidden folder "Application Data\Apple Computer\iTunes". Now proceed like the link tells.
Maybe someone with a voltmeter can check if the issue is really not present in the older firmware (maybe it was just undetected?).
__________________
iPod touch 3G 64GB
Shure SE310
  #25 (permalink)
Old 01-20-2008, 09:38 PM
Clutz's Avatar
Default
I think I will wait for a few days to see if Apple responds to this bug before I take that route. It took me nearly 3 days to transcode & copy all my ALAC files to 256 VBR AACs
  #26 (permalink)
Old 01-20-2008, 09:46 PM
me7 me7 is offline
Head-Fi'er
Default
You know that you won't loose your library? Your iPod will be resynced immediately with iTunes.
__________________
iPod touch 3G 64GB
Shure SE310
  #27 (permalink)
Old 01-20-2008, 10:33 PM
Manny Calavera's Avatar
500+ Head-Fi'er
Default
Originally Posted by zumaro View Post
Ahh the explanation for what so many of us are experiencing - hiss and static noises after the iPod is turned off. Well done Apple - your quality control department must have been fired by now with crap update after crap update slipping through?
I am starting to wonder if Apple out sourced all Ipod QA to India recently....
__________________
Home:Arcam Solo+McIntosh LS340+Pro-Ject RPM 9.1+JA Michell TecnoDec w/upgraded RB250+Dynavector 10x5+Graham Slee Gram Amp 2 SE
Cans:AKG.K601+Beyerdynamic.DT250-80+Senn.HD497+Senn.HD477+Senns.HD650+ATH-ESW9+Shure SE210-K+Jays Q-Jays
Portable Sources:Ipod 40Gb 3G+Black Ipod 80Gb Classic x2 with Belkin Re-Mix Black x2 +3G 8gb Green Nano
Ordered : "Financial Self Restraint 1.0" from my wife !!
Not so new stuff : RSA Predator X2
Lusting After: Rare vinyl Hip Hop records
  #28 (permalink)
Old 01-21-2008, 02:34 AM
mrdeadfolx's Avatar
Default
Well at least I know now that my ipod isnt messed, when I first heard the afformentioned noise I was getting ready to return the damn thing.
__________________
Portable rig: 160 gb iPod Classic -> ALO Jumbo Cryo -> RSA Predator -> UE11 Pro/Sennheiser HD650
Portable rig II: Apple iPhone 3g -> M-Audio IE-40 (UE Triple .fi 10 Pro)
Team "Team Hater"
My Head-fi feedback
  #29 (permalink)
Old 01-21-2008, 02:42 AM
100+ Head-Fi'er
Default
Knowing Apple they won't update the Classic any more, and then 6 months from now charge users $20. Crazy fruit company.
  #30 (permalink)
Old 01-21-2008, 03:23 AM
Amblin's Avatar
100+ Head-Fi'er
Default
Wow. Will Apple be replacing all the Shure and UE IEMs that are damaged by this mishap?
__________________
Current: Zune 30 + Maximo 490S.
Maximo 490S> JVC>FX77>FX55>FX33>
“Let us so live that when we come to die even the undertaker will be sorry.” - Mark Twain
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.3.2
Head-Fi.org
