Head-Fi: Covering Headphones, Earphones and Portable Audio
You are in Whiplash Audio's Premier Sponsor Forum at Head-Fi.org.
To get back to Head-Fi.org's Main Forums, click here.
Go Back   Head-Fi: Covering Headphones, Earphones and Portable Audio > Premier Sponsor Forums and Sponsor Forums > Whiplash Audio Premier Sponsor Forum
Whiplash Audio Premier Sponsor Forum Your Audio and Visual authorities on cables, headphones, speakers, iPod accessories, DIY products, amps of all kinds, home theater; and we specialize in providing excellent customer service!
Reply
LinkBack Thread Tools
  #31 (permalink)
Old 08-11-2009, 03:49 AM
Lil' Knight's Avatar
Send a message via MSN to Lil' Knight Send a message via Yahoo to Lil' Knight Send a message via Skype™ to Lil' Knight
Default
Hmmm, what exactly is the new improvement, Craig?
Does this one work fine with low impedance headphones (IEMs)?
__________________
head-fiebay flickr
  #32 (permalink)
Old 08-11-2009, 04:13 AM
SACD-Man's Avatar
Premier Sponsor
Whiplash Audio
Default
The biggest improvement are:
Black Gates for coupling and Muse for cathode
bypass.....
Killer sound!!
Craig
  #33 (permalink)
Old 08-11-2009, 04:14 AM
SACD-Man's Avatar
Premier Sponsor
Whiplash Audio
Default
Shipping should begin on or around the first week of September!!
  #34 (permalink)
Old 08-31-2009, 08:32 PM
pfillion's Avatar
Default
I have just pulled the trigger on the Mini Millett Max with the upgraded black gates.
__________________
Home: foobar2000 → M2Tech hiFace → Audio-GD DAC-19DSP → RSA Protector #PT070 → JH13 PRO
Portable: iPod Touch 2G → RSA Protector #PT070 → JH13 PRO
"Feedback"
  #35 (permalink)
Old 09-01-2009, 03:57 AM
SACD-Man's Avatar
Premier Sponsor
Whiplash Audio
Default
I guess I should add the details with the new upgraded parts...
Thanks pfillion for reminding me...
There are only a few left. Yikes...
  #36 (permalink)
Old 09-10-2009, 05:01 AM
SACD-Man's Avatar
Premier Sponsor
Whiplash Audio
Default
Here are the new upgraded specs on the improved Mini Millet Max:
Build Specifications:
- Black Gate NX boutique output capacitors (at CA7)
- VitaminQ 0.18µF boutique output bypass capacitors (at CA8)
- Nichicon Muse ES boutique cathode bypass capacitors (at CA2)
- Wima MKP 10 film capacitors used in all amplifier film capacitor locations
- Panasonic FM at all electrolytic power capacitor positions
- 2SA3422/2SA1359 boutique (and very rare!) Toshiba BJT pairs in output Diamond Buffer - set at 50mA class A bias
- Transistors Hfe matched within 2.5%
- Alps RK27 ("Blue Velvet") potentiometer
- Vishay resistors throughout, except R1 (heater voltage knockdown)
- Kiwame boutique output resistors
- 24VAC, 750mA wall plug power transformer (for 120V wall outlet)
- AC input internally fused with 1A slow blow
- Tube circuit and Discrete Buffer protected internally with a 0.5A Polyfuse.
- Power supply set at 27VDC internally
- Kilo machined aluminum volume knob
- Neutrik silver plated 1/4" headphone jack
- 24K Gold plated, Teflon insulated CMC RCA jacks
- 4 wire litz braid signal wiring using Whiplash Audio CFDCT-UP-OCC wire
- 22AWG silver plated copper power wiring.
- Orange tube lights
- Case mounted test points for tube bias
- Bourns trimpot tool for adjusting tube bias
**One pair of Matsushiita 12AE6 tubes included
We highly recommend MiniMAX owners pick up an inexpensive multimeter. These items as well as additional MiniMAX tubes are available at Beezar Audio
They will be in stock by with the next 7-10 days!!
  #37 (permalink)
Old 09-28-2009, 05:31 PM
SACD-Man's Avatar
Premier Sponsor
Whiplash Audio
Default
It's back in stock!!
nice....
Craig
  #38 (permalink)
Old 10-10-2009, 04:22 PM
pfillion's Avatar
Default
The Millet Hybrid MiniMAX is AMAZING with my HF-2 !!
Thanks Craig.
__________________
"Feedback"
  #39 (permalink)
Old 10-11-2009, 04:58 PM
SACD-Man's Avatar
Premier Sponsor
Whiplash Audio
Default
Thanks Craig.
That is a great combo!!
I do like the improvements that were made with this batch!!
Craig
  #40 (permalink)
Old 10-27-2009, 06:36 AM
SACD-Man's Avatar
Premier Sponsor
Whiplash Audio
Default
BACK INSTOCK!!!
WHOA.....
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Powered by vBulletin® Version 3.8.5
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.3.2
Head-Fi.org
