| Whiplash Audio Your Audio and Visual authorities on cables, headphones, speakers, iPod accessories, DIY products, amps of all kinds, home theater; and we specialize in providing excellent customer service! |
11-03-2009, 07:06 PM
Head-Fi'er
Originally Posted by Felsham PO
After reading through several threads on head-fi I decided to get a amp3 pro2.
It has arrived and is plugged in (to me and the charger) as I type. It sounds really clear and spacious to my untrained ear and I am well pleased.
I have a couple of questions that may have been answered previously but I am still not sure about.
I have se530's as my preffered IEM's and it seems that these are one of the worst to have because of their sensitivity and impedance = hiss. They are a bit hissy but will this reduce as the pro2 is burnt in.
Are the REO's a better choice because they are less sensitve and a higher impedance.
Also will the new FW be available as a download?
Many thanks
I just use my se530 with the volume attenuator. Using it turned down from full just a bit can remove most of the hiss w/o lessing the SQ much. It can remove all of the hiss too, but I find I'm willing to put up with very faint hiss in exchange for losing less SQ.
I can't comment about se530 vs RE0 but I doubt the RE0 beats the se530 with attenuator unless you demand great treble. It would be more about sound preference then hiss. As I remember having read reports of hiss with RE0 as well, the improvement in hiss reduction would probably be small at best.
__________________
Home / School: Laptop -> iBasso D3 -> se530
Portable: AMP3 pro2 -> scl4 / se530
Previously owned: se420 (lost them...), e2c (yuck)
11-03-2009, 07:36 PM
Congratulations on your choice of a digital player. I hope that you'll be as happy with your AMP3 as I have been with the two I have purchased (a Pro.1 and a Pro.2).
So far, FW updates have been received via email from Craig at Whiplash Audio, after he posts on an AMP3 thread (probably the AMP3 / Studio thread in his Sponsor Forum) that an update is ready, come and get it. We then send an email to Craig requesting the FW update, and he sends the update attached to the reply email. As far as I know, to date, AMP3 FW updates have not been made available as download links.
__________________
Offline Rig: Pioneer DV563A, DV578A (VD David 1.0 PC) -> Sonicwave Glass Toslink -> Headroom 2007 Ultra Micro DAC (Desktop PSU, VD Nite II PC) -> VD Master 2.0 IC -> stock Purity Audio KICAS Caliente -> Senn HD650 (ALO 18AWG Jena Cryo cable), Yuin PK1, Ultrasone ALO-780
Computer Rig: Creative Emu 1212m (IeGO 70530 PC) -> Glass Toslink-> Same downstream as Offline Rig
Work Rig: iBasso D10 (Topkit) (USB DAC/Amp) -> Yuin PK1, Shure SE530
-OR- AMP3 with (stock) PAA-1 earbuds
Bedside Rig: 5.5G RWA iMod -> ALO VCap Dock (VHAudio OIMP) -> Zynsonix ZYN mkII RCA pair -> ALO/RWA Amphora (iMod version), Mapletree Ear+ Purist HD (VD Nite PC) -> Ultrasone ALO-780, HF-2 (#129), ALO-Modded SR225 (18AWG Jena Cryo cable), SE530, HD600(Cardas)
11-03-2009, 09:29 PM
100+ Head-Fi'er
I took up some recent suggestions on playing FLAC files.
Using an external card seemed to diminish the pops and ticks, but not eliminate them.
Chef's idea of playing classical music worked. No pops or clicks on an half dozen tracks. The only problem is that I rarely listen to classical music on any portable players, other than my Sony CD player.
The MP3's are sounding good and I'll just stick with them until I hear otherwise.
__________________
Walking (Commuting): Amp3 (Pro.2) + RE0
On the lawn: Sony PCDP + iBasso D10 + Ety4s
At the Y: Sansa Fuze + iBasso T4 + q-Jays
DVD Player: Headroom Amp + SoundMagic PL50
At the Office: iBasso D10 (for DAC) + Grado 225
On the Bike: Sansa Clip Plus + Fiio5 + Yuin PK2
11-04-2009, 12:27 AM
Head-Fi'er
Sorry to hear it. I do have one other suggestion. If you use the highest level flac compression, try reconverting to flac level 5 (or lower). I remember putting some files I compressed to level 8 on and they seemed to suffer more from problems. I would think that in theory the lower the compression the less processing needed to play it, especially if the amp3 is not 'optimized' for flac playback. I wish I would have been more through in what I tested but I had only had it for a day and just wanted to get flac playing smooth.
If I have time this weekend I think I will mess around with flac on my amp3 some more to see how mine does. I'd do it sooner but I am also quite satisified with mp3. And I have other pressing matters (*cough* Dragon Age Origins and Borderlands) to attend to. Anyway when I get around to it I will report back.
__________________
11-04-2009, 12:28 AM
100+ Head-Fi'er
I've been converting my flacs to wav. No pops. It takes only seconds and it makes the size only slightly bigger.
11-04-2009, 12:48 AM
100+ Head-Fi'er
Originally Posted by Chef
I think the only reason iPod can even play flac files is because they were designed to play video, which already sets them at about 1600 kb/s files.
My ipod is not rockboxed and it doesn't play flac. Rockboxing would change that but I have no desire to rockbox it because Apple lossless is fine and you can convert many many files in seconds.
11-04-2009, 05:08 AM
Head-Fi'er
Pro2 FW
Craig... Is the software update ready for us? Will we get to use it now?
11-04-2009, 06:58 AM
I'm waiting for another release from hisoundaudio...
Craig
11-04-2009, 07:04 AM
Head-Fi'er
Craig
Oh.. well, you know best. Hope it won't be too long? I suppose getting it right is the most important thing
11-04-2009, 08:45 AM
Junior Head-Fi'er
What sort of volume attenuator do you use, I am not familiar with them. Is it portable?
Thanks.
11-04-2009, 09:00 AM
Junior Head-Fi'er
Hi Craig, I just ordered a Pro 2 from you and just want to check if it's possible to update the firmware using a mac? Tx
11-04-2009, 02:26 PM
100+ Head-Fi'er
FLAC files are all converted at the default or 5 setting. So no luck there.
__________________
11-04-2009, 03:37 PM
Head-Fi'er
Rockbox has a lot of nice features like Zooming in when viewing pictures, customizable skins, playing non-proprietary formats and a very nice user interface (better than iPod in a lot of ways). The only reason I don't use it 100% of the time is because it's video playback is lacking (I haven't bothered to check if they got around to improving it).
That aside, flac is better in general just because you don't have to open up iTunes (which is an incredibly bloated and annoying program). I guess there's probably a way to rip to apple lossless without iTunes, but I'm not jumping thru hoops to satisfy Apple.
11-04-2009, 04:51 PM
Head-Fi'er
Thanks.
The one that typically comes with SE530.
Shure - Attachable Volume Control
__________________
11-04-2009, 06:58 PM
Junior Head-Fi'er
Of course!
Cheers
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
Powered by vBulletin® Version 3.8.4 Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.3.2
Head-Fi.org
