| Whiplash Audio Premier Sponsor Forum Your Audio and Visual authorities on cables, headphones, speakers, iPod accessories, DIY products, amps of all kinds, home theater; and we specialize in providing excellent customer service! |
LinkBack | Thread Tools |
Yes, sure it can be done, and I don't like to be questioned with the use of capitalization, unless it's being used in the beginning of a word in new sentence..
So, you have heard of this being done?
Other DAP's where you can change this through software. Rockbox software can do it. And European Ipods amongst others has a limiter volume cap. written in their software that can be modified to make it play it as loud as in the US. |
Thank you JupiterKnight. If other's are having this volume problem, it's likely those who use full size 'phones for the most part. I'm sure if enough people are having the same problem, and something can be done, HiSound will fix it. With my IEM's it's fine, but I don't like using them nearly as much. Anyways, you're right. It's getting late. Thanks for your reply, it helped!
Thank you for posting that. Your originally posted experiences with a 16GB card and the two versions of FW on your Pro.1 (originally the opposite of my own experiences) were certainly on my mind during my previous post. Differences in AMP3-Pro.1 behavior that you have experienced between installing the V5.31 FW with and without a format of the data area show the format to be more of a significant factor in a FW installation than I would have previously thought. I always checked the "Reformat Data Area" checkbox to satisfy my own persnickediness about doing a "clean install". It's good to know that, sometimes, that persnickediness of mine yields some welcome results. Again, thanks for posting your experiences. It's reassuring about the hardware configuration management going into the Pro.1 when different Pro.1 units show the same behavior after installing the same FW when the installs are performed in the same way.
__________________
Offline Rig: Pioneer DV563A, DV578A (VD David 1.0 PC) -> Sonicwave Glass Toslink -> Headroom 2007 Ultra Micro DAC (Desktop PSU, VD Nite II PC) -> VD Master 2.0 IC -> stock Purity Audio KICAS Caliente -> Senn HD650 (ALO 18AWG Jena Cryo cable), ALO-modded SR225 (Becote cups, 18AWG Jena Cryo recable), Yuin PK1 Computer Rig: Creative Emu 1212m (IeGO 70530 PC) -> Glass Toslink-> Same downstream as Offline Rig Work Rig: AMP3 with Senn MX-660 earbuds Bedside Rig: 5.5G RWA iMod -> ALO VCap Dock (VHAudio OIMP) -> Zynsonix ZYN mkII RCA pair -> ALO/RWA Amphora (iMod version), Mapletree Ear+ Purist HD (VD Nite PC) -> Ultrasone ALO-780, HF-2 (#129), SE530, HD600(Cardas) |
__________________
Let me pair the 2 up... The JH13's are living up to the hype. The universal synergy I have not heard from any headphone... I HIGHLY recommend!! Craig
__________________
Qables appoints Reseller: http://www.head-fi.org/forums/f75/qa...seller-275199/ Whiplash Mini Millet Max! http://www.head-fi.org/forums/f149/i...et-max-404959/ Styleaudio DAC/AMP: http://www.head-fi.org/forums/f149/s...p-sale-416209/ AMP3: www.head-fi.org/forums/f149/new-mp3-player-pdaa-called-amp3-amazing-425540/ Prototypes and New Designs http://www.head-fi.org/forums/f149/p...ts-etc-442942/ |
Innovative use of the Haiku...Well done!
__________________
Headphones: Ultrasone Proline 2500; Yuin PK1; Shure SCL4 & SE530; Senn IE8 & 580 (mod); Audio Technica ATH-ESW9; Grado HF2-F1 & RS1; Denon AH-D7000; AKG K81dg & K701 Source(s): Many. Favourites: AMP3 Pro 2; Sansa Clip; Sansa Fuze; Zune 120; Ipod 32gb Amp(s): Ibasso D10; Eddie Current EC/SS FOR SALE: Hewlett Packard Ipaq 110 PPC; Feedback |
In my past experiences with silver cable, it tended to make the sound overly bright, but that is not the case with this wire. Bass is deep, tight, and realistic. Imaging is absolutely suberb with a very lifelike soundstage, both in width and depth. As Craig stated, the wire needs about 150 hours for optimum sound, so I will hold off on a review until that time. As the wire is solid, it is not as flexible as stock stranded wire, but the sound is worth any inconvenience due to the stiffness.
__________________
RON KERLIN Ft Myers, FL SOURCES: Shanling PCD3000A, AMP3, iRiver H140 & (2)H-CF32, Sony S-618 & A-820, Panasonic SL-CT800. AMPS: RWA Signature 30.2, Little Dot T-150, SOHA (JISBOS), iBasso P3+, D10, D4, T3, Xin SM-Micro. PHONES: AKG K-1000, UltraSone Ed.8, AKG K-340, Maestro GMP8.300D, Westone ES3X, Sony F1, Sony EX700, FreQshows, Yuin OK1,2,3, G1, G2A, Panasonic WF6000T, KSC-35, 75, PortaPro Anniv. NON-HEADPHONE AUDIO: Denon Home Theatre Amplifiers, Definitive Technology Surround system, Magnaplan MG12 Speakers. |
I was going to do that anyway, based on how much of my listening I'm doing with my AMP3's (and, correspondingly, how little with my larger, desktop, wall-powered gear). But these testimonials put a little more oomph behind it and add a good dollop more gumption to my doing it (yes, I wrote both dollop and gumption).
__________________
Was pleasantly surprised to come home and find a delivery from Whiplash which I tore open like a kid at Christmas. Inside I was amazed to find my recabled Zino's (I am going to have to post a picture, they are ab so lute ly stunning) They also surprised me with their wide open sound and deep bass. I'm not used to hearing such magic from an inexpensive headphone with absolutely no burn-in.
Secondly, I unwrapped the TWcu LOD cable with its Viablue connector. Is there an award out there for like the best looking LOD ever? This would win it. Again, a picture is needed. I can't comment on it's sound yet obviously but if it's anything like it looks..... Thirdly, the much sought after and highly coveted Amp3 Pro2. So, with a good dollop of gumption, (where have I heard that?..lol) I opened the box, found the power cord etc and plugged the puppy in to charge. There are no instructions to follow so I have just a couple of questions. When the Amp3 Pro2 is fully charged, will the light go out on the unit? Secondly, is there firmware someplace that I should be downloading and installing? Not being the sharpest knife in the drawer or one who's elevator does not reach the top floor, I mistakenly purchased a 32 GB SDHC card for this unit. I forgot that it takes the Micro flavor of the SDHC. Luckily I do have a brand new 8GB Micro hanging around which I plan to use for now. If anyone feels gracious enough to help with instructions explaing the proper order in which to proceed I will send them 5 million dollars in small untraceable currency. OK, I can't do that but I will say thank you and mean it. Alright, enough writing, I should eat something to calm these shaking hands so I don't screw anything up. |
here's the manual for the pro1 - the faction and buttons should be pretty similar.
| Thread Tools | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Mini CD-Pro2 Transport Kit | sbelyo | DIY (Do-It-Yourself) Discussions | 39 | 08-18-2009 04:52 AM |
| What makes philips Pro2 good | 92135011 | Dedicated Source Components | 11 | 05-26-2008 04:18 AM |
| FS Porta Pro2 from Circuit City | eat2na | Headphones For Sale / Trade | 5 | 11-14-2005 09:46 PM |
| Where can I get a pair sensaphonic pro2's? | Mr Do | Headphones (full-size) | 1 | 07-15-2005 11:53 PM |
| Pro2 PH-S560 | cjob68 | Headphones (full-size) | 0 | 03-16-2005 01:45 AM |
