Originally Posted by jcx
if for Edition 9 you have 96 dB SPL re 1 mW…
Originally Posted by ultrapaul
From Florian:
•SENSIVITY in dB/mW for the Ed. 9 is 96 dB and it shows based on the impedance (pre-amp plus divers) at what kind of levels how much VOLTAGES are ... frequency 1 kHz / sinusodial.
sensitivity spec assumption looks to be definitively verified
so how much power do you need to cover dynamic peaks in music without clipping?
then ~120 dB peak SPL will require ~+24 dB mW = 250 mW_rms
250mW_rms requires ~ 130 mA, 3.9 V peak amplitude into 30 Ohms
the Pico specs look to have this covered
no equations! (or rather I cranked them for you already)
you might want to look at HeadWize - Article: Preventing Hearing Damage When Listening With Headphones (A HeadWize Headphone Guide)
just to get some idea of dynamic peak SPL requirements and safe average listening level
power handling specs are more about physical damage from overheating the voice coil and have little to due with audio drive requirements
From Florian:
These measurements are mixing loudspeaker measuring applications modalities with the reinforce instrument headphones. It is totally unusual to realize such tech data for headphones:
•"Power Handling Capacity" of 1500mW (IEC <> made for loudspeakers!!!). Short extract: "Power handling capacity Impedance Recommended input power Dispersion ... 2000 W IEC norm 268-5 4 ohms/loadspeaker nominal 1500 – 3000 W into 4 ohms .... In the eighties we had some "destroying lever" data's, but also this was finished in IEC ...
Hope that helps.
Florian gives 1500mW as the "Power Handling Capacity"
and as I stated the number is useless for you - tells you how much continuous power needed to cook your headphone - not how much required to drive it with adequate dynamic SPL headroom
its nice that the 250 mW required to drive the Edition 9 to 120 dB SPL is less than 1500 mW - but this isn't a hard requirement since the power handling capacity is a continuous rating and 120 dB SPL peaks should be very short and infrequent in music listening so the voice coil has time to cool off
at low frequencies most drivers will bottom out on the magnet backplate at much lower power input than the Power Handling Capacity
__________________
"Along these same lines, a survey conducted in 1995 by Yankelovich Partners reveals that 8 percent of those polled had participated in “New Age” rituals and practices such as contacting the dead, spirit channeling, investigating past lives, mental telepathy, healing through mind power or crystals, consulting a fortuneteller or astrologer, making plans based on their horoscope or presenting uncontrolled, sighted listening impressions in internet forums.[ref17] This survey includes practices that are not exclusively Pagan. However, if we apply the survey percentage of 8 percent to the U.S. population as a whole, then it does indicate that 21.6 million people were apparently open enough to New Age, Pagan, and other alternative practices to participate in them."
