Head-Fi: Covering Headphones, Earphones and Portable Audio
Support Head-Fi by starting your Amazon.com shopping by clicking here
Follow headfi on Twitter!
Follow Rocky Mountain Audiofest (RMAF) on Twitter!
Head-Fi Is Sponsored By:
Featured
Head-Fi's Sponsors
(Premier Sponsors bolded)
Featured
Can Jam '09
(2009 International
Head-Fi Meet)
Impressions,
Reviews, Photos
Can Jam '09 graphic
courtesy of Edwood
Click on the links below
for Can Jam '09 photos,
impressions and reviews:
blubliss 1, 2, 3
dallan 1, 2, 3, 4
santacore 1, 2
nhat_thanh 1, 2
vpivinylspinner 1, 2, 3
amb 1
augustwest 1
eaglejo 1
johnsonad 1
shellylh 1
Jon L 1, 2, 3, 4
Germancub 1
zippy2001 1
IPodPJ 1
bhd812 1
Edwood 1, 2
abellaw 1, 2
minidiscs 1
atothex 1
HighLife 1
achristilaw 1
SiBurning 1, 2, 3, 4
SiBurning 5, 6, 7
LFF 1
Iron_Dreamer 1
doping panda 1
morphsci 1
ironbut 1
shaizada 1
jasper994 1, 2
jp11801 1
Uncle Erik 1
drubrew 1
(More impressions/photos
still being added.)
Head-Fi Blogs
and Facebook
Check out Head-Fi's new
Blogs section.
Featured Head-Fi Blogs:
Jude's "Take My Word"
 From Japan - by Sasaki
Currawong's Blog
Start your own Blog!)
Attention
Facebook Users
Join the official
Head-Fi.org
Facebook Group
Featured
Head-Fi's Sponsors
Featured
  #76 (permalink)
Old 01-03-2007, 04:40 PM
DDF's Avatar
DDF DDF is offline
100+ Head-Fi'er
Default
Originally Posted by Skylab View Post
Also, DDF, w/r/t level-matching, I'm not sure I understand your point. I used a pink-noise track to match the levels of the amps, using the same headphones, to within 1db. Why wouldn't this work? Genuinely curious here. It seems that if all the amps were delivering exactly 80db at the headphones on the same pink noise track, then they're pretty well level matched...
Hi Skylab,
Thanks for clarifying that your tests used the same headphone, which is very important. For the uninitiated: different headphones can give the same SPL in free space (i.e. not on a head) but very different perceived SPL when used. Headphones produce different SPLs into different acoustic loads (seals), and each headphone is often uniquely sensitive to differences in the seal. So, lets say the gain of one amp is adjusted to measure 80dB in free space on one headphone with an RS meter, then repeated with another set of headphones; the perceived levels will very likely be slightly (1 to 2dB) to moderately (3 to 4dB) different between the two headphones (even if the RS meter gave the same SPL). This isn't a "major" level of difference but its more than enough to change a quality perception: for a careful listener, even 1 dB louder will sound better, all else equal. What this means is that to begin to really get a fair assessment of the small differences in amps, all the comparisons need to occur on one set of headphones. If multiple headphones are used, a good break should be taken between cans.
When all amps are used on the same headphone (sounds like they were), then its more accurate a test if the voltage level into the phones is measured, than if SPL is measured (the voltage to SPL will always be the same on the same phones). Even quite small differences in SPL meter placement will result in notable (easily 1, maybe 2 or 3 dB) reading differences out of the headphones. So even if the meter reads the same in different measures, you could be a couple dB out due to even small differences in placement. With a voltmeter and a careful hand on the amp volume control, you can easily nail this down to 0.1 dB matching. In order to get around any differences caused by amp o/p impedance, I measure the voltage using the actual headphones as the load. Take a y-adapter, cut off one connector, and measure the voltage on the stripped cables.
Skylab, I hope you don’t take this as a nock on your results. Your tests are very valuable, and it sounds like you were pretty careful. It’s just that by using a voltmeter instead of an SPL meter, you can helpfully further lessen some of the uncertainty, which may make a difference when comparing amps that are close to each other in SQ.
The other benefit beyond accuracy is that it fast to use a voltmeter to adjust the amps. If you don’t have a voltmeter, a PC sound card will work well. The amp o/p is fed into the sound card i/p and monitored. A great deal of freeware exists that will give a fast level measure (e.g. RMAA).
Dave
PS for context: I used to work in audio and at one time spent months in the lab designing/measuring/specing headphones, on everything from head and torso simulators, to telecom pinna to measuring headphones with Etymotic probe mics in ears of real subjects (more like victims; they didn’t take kindly to all the scotch tape running up their neck ). Measuring headphones present some “unique and difficult” (i.e. total PITA) challenges.
  #77 (permalink)
Old 01-03-2007, 04:47 PM
Skylab's Avatar
Headphoneus Supremus:
Reviewerus Prolificus
Default
Originally Posted by kramer5150 View Post
IMHO it should be noted that the Practical Devices XM4 has socketable OPamps. Its a dual OP amp design with one chip buffering the other (I think someone please correct me). I think its the only one in the review with this feature. Would it be possible to update your review with some commentary, on which amps have socketed OPamps and which do not?
What that means is the chips can be rolled for a custom sound that synnergizes with many different cans.
I wouldn't be surprised if it could rank higher on your preference list with a little OP amp rolling.
Thanks again for an excellent review, Mods cast my vote for a sticky.
This is quite true, that it can have op-amps changed. I probably should have said - I'm not into op-amp rolling, so I did not factor that in. But you're right - for another person, this might change the rankings for them.
__________________
PLEASE NOTE: Due to the volume of PM's I have been receiving in connection with my reviews, I no longer have the time to answer PM's from people with zero posts. Please read head-fi first before asking questions.
Team GO-U-NORTHWESTERN
Pics:
Main Home Rig; Bedside Rig; Office Rig; Portable Rig;
Headphones: JVC HP-DX1000, HA-RX900; Headphile Deep Cup Darth Beyers VXD3,VXD4; Beyerdynamic DT990/600 (Manufaktur) DT770/600 (Manufaktur), DT880/600 Balanced (Manufaktur); HiFi-Man HE-2 Planar Magnetic; Sennheiser PXC-350; Shure SRH840
Home amps: Ray Samuels Audio Stealth (Mullard ECC32/CV4003); Decware Zen CSP-2 (Amperex BB 6DJ8/Sophia Princess 274B); Darkvoice 337 (GEC 6AS7G's/Tung-Sol mesh plate 6SJ7GTs); Wheatfield Audio HA-2 (Mullard ECC32/GEC 6AS7G/GEC U52); Ming-Da MC84-C 07 (Mullard CV4004/EL84/EM87); Audiotailor Jade (GEC 6AS7G/Sylvania 5751); J. Sound Lab Headphone (Mullard 12AT7); Audio-GD Phoenix; Musical Paradise MP-301 (Ken-Rad 6V6GT/Mullard 6AU6)
Portable Amps: Ray Samuels Audio P-51 Mustang; Decware ZenHead; Meier Audio 2Move, XXS; Qables iQube
Sources: Denon DP59L table + Clearaudio Maestro Wood / VPI Scoutmaster + Benz Micro Wood L2 > Audio Electronics PH-1 DJH Phono Preamp; Music Hall 25.2 DAC; Denon DVD-5900;Red Wine Audio iMod iPod (Apple Lossless) & ALO VCap dock; Sony SCD-555ES SACD player
Loudspeaker system: Krell KAV250 Preamp>Sunfire Signature II Power amp > B&W Nautilus 800 Signatures + Velodyne FSR-1500/Martin Logan Descent
Tube testers: B&K Dyna-quick 650 & Dyna-Jet 606
Head-fi feedback
  #78 (permalink)
Old 01-03-2007, 04:54 PM
Jahn's Avatar
Headphoneus Supremus Prolificus:
Head-Fi's most prolific poster.
Default
i just have to laugh at the size of the larocco versus the other amps. that thing is a beast! didja have to put it right next to a tomahawk like that? hehe. i'd still love to lug it around if it fit my camera bag that i always use for my portable rig (but it doesn't) - and that bag is about as big as i want to go when walking the dog and such, hehe.
__________________
Team "Curse You, Head-Fi!"
Home Rig (The "Tower of Power"): Lan-modded E-MU 0404 => 3-ft Dayton Glass Optical Digital Out => Lan-modded Lite DAC-AH => Cardas Neutral Reference ICs * => Melos SHA-Gold "Maestrobated" by Carlo w/ DACT CT1 10K-2 Stepped Attenuator w/'50s "D"-Getter Holland Amperex (Valvo) "PINCHED WAIST" PCC88/7DJ8 tubes with HAL-O 9 Damping Instruments on Type IV Vibrapod Isolators and Cones => PRE-AMP TO: Audioquest Diamondback ICs => STAX SRM-1/MKII Pro => STAX Lambda Pro Earspeakers on a Woo Audio Aluminum Headphone Stand or HEADPHONE AMP TO: Headphile BlackSilver-recabled Grado HP-2 w/DT770 Headband & Headphile Zeta Port C-Pads ("Darth Grados") or Headphile BlackSilver-recabled & impedance-tweaked DT770/600 Ohm ("Darth Beyers" stolen by Sister) => SR325...as endcaps on my Headphile Stand!
*Vinyl/Tuner Rig: Goldring GR-1 Turntable w/ Grado Prestige Gold Cartridge => S.A.E. P102 Preamplifier w/ Phono Stage => Headphile Blacksilver Interconnects to the Melos
Portable Rig (The "Dog Walkin' Rig"): 30gig 5G iPod Video(Black) w/BestSkinEver (Back/Sides) & InvisibleShield (Front/Scrollwheel) & PodsPlus Black Aluminum Case => Apple Radio Remote w/Sumajin Smartwrap => RnBAudio "The Jahn" Custom BlackDiamond 4" Mini/Mini Cable w/Gold Straight Plugs => "The Green Hornet" w/ "M" mods by Ray Samuels Audio => Grado Head-Fi Series One Headphones #472 with Reverse Bowl pads and DT770 Headband OR an AKG K81DJ w/The Cable Turtle and Replacement Sennheiser HD25 Velour Pads!
Here's my Buyer/Seller Feedback!
  #79 (permalink)
Old 01-03-2007, 05:04 PM
Skylab's Avatar
Default
Originally Posted by Jahn View Post
i just have to laugh at the size of the larocco versus the other amps. that thing is a beast! didja have to put it right next to a tomahawk like that? hehe. .
As you guessed, I did that on purpose. I love the PRII, but it's a different beast compared to the Tomahawk to be sure.
__________________
Pics:
Head-fi feedback
  #80 (permalink)
Old 01-03-2007, 05:09 PM
Default
I'll chime in -- most excellent review -- a "must-read" primer for portable amp considerations. And another x vote for possible sticky status....
__________________
An ex-pro rock guitarist, so I know what live music REALLY sounds like!
  #81 (permalink)
Old 01-03-2007, 05:46 PM
jinp6301's Avatar
Default
great great review, and i Xnd for a sticky status
skylab, have you thought have making a value/quality list?
__________________
Team Super Minimal!
Home: Asus eeepc 701 -> bantam cable dac -> XP Portable Amp -> Grado HF-2
Portable: ipod 80gb 6G -> Koss Portapro/Altec Lansing im716 (modded)
LastFM
Feedback
  #82 (permalink)
Old 01-03-2007, 05:47 PM
robm321's Avatar
Default Thank You!
Very well done - I appreciate the comparisons.
I also wish the Xin amps were included, but this will help me get a grasp of where the amps rate without having to sift through thread after thread of opposite opinions.... Thanks again!
(...considering building a portable rig)
__________________
Rob
headfi feedback
audiogon feedback
Von Schweikert VR4 jr / AKG K-1000 / Grado HP-2 / Grado GS-1000
Portable - Imod - Xin Supermini III - ALO Cryo mini to mini - Shure E500/Audéo PFE
  #83 (permalink)
Old 01-03-2007, 06:00 PM
Skylab's Avatar
Default
That's a very interesting idea, although a tricky one to be sure. Especially when feautres start to come into play, and how valuable they are to different people.
I know for ME, the Hornet has the best value, even though its the second most espensive, because of its performance versus price, size, features, etc. But in some ways the Headphonia should be the winner, based on its lower price versus its performance and in light of all of its features.
I think it's best for me to leave the value judgements to each person individually.
__________________
Pics:
Head-fi feedback
  #84 (permalink)
Old 01-03-2007, 06:12 PM
100+ Head-Fi'er
Send a message via AIM to patgod
Default
Skylab, your post is the perfect example of the outstanding thoughtfulness, care and passion that never ceases to amaze me about this site. Great, great job, immensely invaluable, and I also recommend for a sticky. A great post for newbies to get a better understanding of what portables are available.
One suggestion: Have you thought about linking to the various manufacturers? (if allowed...) I found myself thinking, "hey, I've never heard of THAT amp before, how much is it, where can I get more info?" Just a thought...
-pat
__________________
Sources: iTunes/iPod/Mac
Dac(s): Squeezebox/m-audio Transport
Amps: Total Bithead/Eddie Current EC-01/headsix/go-vibe 6
Cans: ety 6i/grado sr60/senn 280/ Senn 555/Sen 580
In Need of: Better USB Dac
Build websites in drupal
  #85 (permalink)
Old 01-03-2007, 06:31 PM
100+ Head-Fi'er
Default
Hornet & Tomahawk:
www.raysamuelsaudio.com/
Xenos:
http://www.aptecpro.com/
LDM+:
www.little-tube.com
Practical Devices XM-4:
www.practicaldevices.com
Go-Vibe:
www.go-vibe-headphoneamp.com
Headphonia:
www.headphonia.com
Larocco Audio Pocket Reference II:
http://laroccoaudio.net/pr2/pr2.html
Don't have a webpage for the Xtra X-1 though...
Feel free to copy and paste, Skylab, if you want to.
-The Grinman
__________________
Unabashed Utada Hikaru Fan
Portable: Zune 30 > xtrememac FS1
So empty now...
  #86 (permalink)
Old 01-03-2007, 06:33 PM
Packgrog's Avatar
500+ Head-Fi'er
Default
Originally Posted by JLai View Post
Great review.
I'm surprised TH fans aren't up in arms about the Hornet M being higher ranked.
Why? It's a different and more powerful beast. Did anyone expect the Tomahawk to have BETTER sound than the Hornet M? I know I didn't. I was just hoping it would be close (and still excellent and better than most other portable amps), which apparently it is. There's only so much that can be expected from something this TINY. I love it, but if Skylab had ranked it above the Hornet M, I would have written it off as new-purchase fanboy glee. Heh.
Definitely agreed on the review itself, though. Very nicely informative! Thanks, Skylab!
__________________
Headphones: Future Sonics Atrio m5 | Future Sonics EM3
Sources: Rockboxed iHP-120 | iBasso D1 | Cowon A2 30GB | iPhone 3G 16GB
Amplifiers: iBasso D1
Music: Last.fm | Pandora
  #87 (permalink)
Old 01-03-2007, 07:03 PM
rhymesgalore's Avatar
500+ Head-Fi'er
Default
Btw, you have missed one VITAL point for the RSA amps, which might be of uttermost importance to the user:
They work under water
If this isn't the ultimate feature of all
__________________
"They that give up essential liberty to obtain a little temporary safety deserve neither liberty or safety." Ben Franklin, 1759
  #88 (permalink)
Old 01-03-2007, 07:55 PM
JLai's Avatar
1000+ Head-Fi'er
Default
Ahh yes. I think in general, people who have heard both have voiced the Hornet edges out the TH ever so slightly. Not just 1 month ago, I was seeing threads on why the TH is better and how someone could straight up trade a used TH for a Hornet M (even though the Hornet costs $100 more). Glad to see the fanboyism is calming down.
  #89 (permalink)
Old 01-03-2007, 08:03 PM
3x331m's Avatar
Default
I like this kind of thought..... We, Head-Fiers, are not bunch of air-heads...
  #90 (permalink)
Old 01-03-2007, 08:04 PM
Head-Fi'er
Default
Great job, excellent and very useful review!
Thanks for sharing, Skylab
Sorry for my wallet
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.3.2
Head-Fi.org
