Head-Fi: Covering Headphones, Earphones and Portable Audio
Support Head-Fi by starting your Amazon.com shopping by clicking here
Follow headfi on Twitter!
Follow Rocky Mountain Audiofest (RMAF) on Twitter!
Head-Fi Is Sponsored By:
Featured
Head-Fi's Sponsors
(Premier Sponsors bolded)
Featured
Can Jam '09
(2009 International
Head-Fi Meet)
Impressions,
Reviews, Photos
Can Jam '09 graphic
courtesy of Edwood
Click on the links below
for Can Jam '09 photos,
impressions and reviews:
blubliss 1, 2, 3
dallan 1, 2, 3, 4
santacore 1, 2
nhat_thanh 1, 2
vpivinylspinner 1, 2, 3
amb 1
augustwest 1
eaglejo 1
johnsonad 1
shellylh 1
Jon L 1, 2, 3, 4
Germancub 1
zippy2001 1
IPodPJ 1
bhd812 1
Edwood 1, 2
abellaw 1, 2
minidiscs 1
atothex 1
HighLife 1
achristilaw 1
SiBurning 1, 2, 3, 4
SiBurning 5, 6, 7
LFF 1
Iron_Dreamer 1
doping panda 1
morphsci 1
ironbut 1
shaizada 1
jasper994 1, 2
jp11801 1
Uncle Erik 1
drubrew 1
(More impressions/photos
still being added.)
Head-Fi Blogs
and Facebook
Check out Head-Fi's new
Blogs section.
Featured Head-Fi Blogs:
Jude's "Take My Word"
 From Japan - by Sasaki
Currawong's Blog
Start your own Blog!)
Attention
Facebook Users
Join the official
Head-Fi.org
Facebook Group
Featured
Head-Fi's Sponsors
Featured
  #751 (permalink)
Old 06-26-2007, 03:40 PM
MrFaust's Avatar
500+ Head-Fi'er
Default
Has anyone managed to find the iPower 500mAh Li-On rechargeable battery for less than $14.97 US ?
__________________
__________________________________________________
.:: Minimalist Rig ::.
Black 5.5G 80GB iPod (Rockboxed) > Koss KSC35 (recabled by APureSound)
Feedback: ebaY Head-Fi / Team: APureSound
  #752 (permalink)
Old 06-26-2007, 03:46 PM
mcmyers's Avatar
100+ Head-Fi'er
Default
Originally Posted by slattikarma View Post
Great thread. I have just read all 38 pages and feel like I need to take a nap! Thank you Skylab! Your dedication is incredible.
I started off the thread wanting a Hornet, then a Headphonia, then a Tomahawk and now a Porta Corda Mrk III... and I feel that may change to a Corda Move in a few days time.
One point I'm a bit confused on, that I would like clarified for the benefit of newbies such as I.
What exactly is the benefit in buying a DAC amp vs a normal amp?
For example, when using a laptop, would the DAC amps that use USB such as the Bithead, Corda Move or Headphonia be preferred over a non DAC amp that uses the headphone jack such as an RSA Hornet or Tomahawk?
Is there much of a difference? Or is the advantage solely in that you can power the amp from the USB?
I'm just a tad bit confused here.
I'm trying to decide what to buy for my Beyer DT770/80, that I plan to use with my macbook and on the road with my ipod.
Thanks.
I'm no expert, but my understanding is that a DAC with USB will let you bypass your laptop's internal soundcard, as well as all the noisy inerts of your computer and give you a cleaner signal. So unless you have a great internal soundcard, a USB DAC is going to give you better sound from your computer than if you just amped straight out of the computer. Hope that makes sense.
  #753 (permalink)
Old 06-26-2007, 03:51 PM
itsborken's Avatar
Default
If you buy a normal amp, you just connect the line out of the pc to the line in of the normal amp. line out signals are created by the PC soundcard (or onboard soundchip) and they don't produce the greatest quality sound for music. They are fine for games crash boom bang. The noise from fans, etc. also degrade the sound quality going into the amp.
If you take the digital output of the computer and let an external DAC convert it, the sound quality is better (noise is blocked since digital output is just 0 & 1s). The DAC component quality is generally better than that of the soundcards too.
So get a DAC amp and you get extra flexibility. You can listen to better quality music on your PC, yet it is still portable so it works with your DAP when needed.
That is a benefit too; you don't need to carry a wall wart PS with you when you travel (and don't go through batteries so quickly).
I should add you can get separate portable DACs and amps too. If you go that route then the DAC could be powered by the USB but the amp wouldn't be. Some portable DACs support spdif/TOSlink directly if you had a high quality source that could use it.
  #754 (permalink)
Old 06-26-2007, 04:25 PM
Head-Fi'er
Default
Wow. You guys are quick.
Thanks for the clarification. Makes sense.
So, that would mean a DAC amp would also be very useful for those that use their laptop for audio production?
  #755 (permalink)
Old 06-26-2007, 07:09 PM
cooperpwc's Avatar
Default
For this use, the DAC amp would absolutely be preferred and in each of the cases you discuss would be expected to give a significant improvement in sound quality over the headphone out of the laptop. There are two reasons for this: 1) the DAC sections of the amps you name are far better than the sound card of most laptops, and 2) you are doing the conversion of sound outside the laptop and away from all the internal electrical interference.
I am not however comparing the amp section of any specific DAC amp with any specific non-DAC amp. I am nonetheless confident that even the finest portable amp will be a disappointment when used with the inferior headphone out of most laptops.
__________________
Portable: iPhone 3GS > UE Triple-Fi 10 Pro (Westone cable)
Movies: Pioneer DVR-550H > Denko ETPC interconnect > Millet Hybrid (diamond buffers) > Darth Beyer V3 (Wenge Blackmax)
Home: Thinkpad T60 (Maxtor external HDD, Foobar) > USB Monica > Headphile Blackmax interconnect > Earmax Pro (1949 Valvo ECC81 coin base + matched 1965 Philips E188CC) > Beyer DT880 (600 ohm)
(Other favourite gear: Headroom MicroDAC, Meier Headsix, iPod Video 30GB, iRiver iFP-799, Sony D77 eggos)
  #756 (permalink)
Old 06-26-2007, 07:21 PM
epaludo's Avatar
Default
Definitely.
The headphone out of a laptop amplifies the signal. So connecting a headphone out to an external amp will amplify the signal twice, which is really bad. You'll get more distortion. What do you need is to connect a line-out to the amp. If your laptop doesn't have a line-out, that's where the external USB DAC comes in. So the DAC will convert the digital signal to analog. And then you'll connect the DAC, non amplified, line-out to the amp.
If you're using a DAC/AMP combo, you'll be provided by a headphone out directly ...
__________________
My Profile ...
  #757 (permalink)
Old 06-27-2007, 02:50 AM
facelvega's Avatar
Default
Originally Posted by epaludo View Post
Definitely.
The headphone out of a laptop is bad because it is bad, not because of dual amplification. Does double amping increase distortion? Yes, nominally. But many sources including a lot of beloved standalone dacs amp their line out signal with opamps, and everyone who has a separate preamplifier (a real one, that is, and not just a switchbox) in their home system does the same. Nonamped line outs can be great, but they are not an end-all. This is a head-fi myth that has been growing in the last few months and needs to be nipped in the bud.
__________________
team planar
team Sturzhelm
team MB
  #758 (permalink)
Old 06-29-2007, 04:04 PM
Skylab's Avatar
Headphoneus Supremus:
Reviewerus Prolificus
Default
OK I now have about 60 hours on my Meier MOVE, and it's improved some from cold (where it already sounded very good). Full review to come soon, but this amp is excellent. Much like other Meier amps, it features a smooth yet detailed sound, but it's a little warmer like the Opera is. Still very transparent, clean, and very musical. It's going to fare very well.
__________________
PLEASE NOTE: Due to the volume of PM's I have been receiving in connection with my reviews, I no longer have the time to answer PM's from people with zero posts. Please read head-fi first before asking questions.
Team GO-U-NORTHWESTERN
Pics:
Main Home Rig; Bedside Rig; Office Rig; Portable Rig;
Headphones: JVC HP-DX1000, HA-RX900; Headphile Deep Cup Darth Beyers VXD3,VXD4; Beyerdynamic DT990/600 (Manufaktur) DT770/600 (Manufaktur), DT880/600 Balanced (Manufaktur); HiFi-Man HE-2 Planar Magnetic; Sennheiser PXC-350; Shure SRH840
Home amps: Ray Samuels Audio Stealth (Mullard ECC32/CV4003); Decware Zen CSP-2 (Amperex BB 6DJ8/Sophia Princess 274B); Darkvoice 337 (GEC 6AS7G's/Tung-Sol mesh plate 6SJ7GTs); Wheatfield Audio HA-2 (Mullard ECC32/GEC 6AS7G/GEC U52); Ming-Da MC84-C 07 (Mullard CV4004/EL84/EM87); Audiotailor Jade (GEC 6AS7G/Sylvania 5751); J. Sound Lab Headphone (Mullard 12AT7); Audio-GD Phoenix; Musical Paradise MP-301 (Ken-Rad 6V6GT/Mullard 6AU6)
Portable Amps: Ray Samuels Audio P-51 Mustang; Decware ZenHead; Qables iQube
Sources: Denon DP59L table + Clearaudio Maestro Wood / VPI Scoutmaster + Benz Micro Wood L2 > Audio Electronics PH-1 DJH Phono Preamp; Music Hall 25.2 DAC; Denon DVD-5900;Red Wine Audio iMod iPod (Apple Lossless) & ALO VCap dock; Sony SCD-555ES SACD player
Loudspeaker system: Krell KAV250 Preamp>Sunfire Signature II Power amp > B&W Nautilus 800 Signatures + Velodyne FSR-1500/Martin Logan Descent
Tube testers: B&K Dyna-quick 650 & Dyna-Jet 606
Head-fi feedback
  #759 (permalink)
Old 06-29-2007, 04:58 PM
100+ Head-Fi'er
Default question
Hi I have been using the hornet as my portable amp with the 5G ipod as my source with the triple fi. But I find that the difference in the sound generated from triple fi between amp and unamp is minimal.
  #760 (permalink)
Old 06-29-2007, 05:43 PM
Nattydraddy's Avatar
100+ Head-Fi'er
Default
Your internal soundcard gets normally bypassed. But you can get noise from your computer. You don´t get EMV form your computer in the DAC. But you can get hum through the USB cable.
The only easy solution for that is to use optical out.
  #761 (permalink)
Old 06-29-2007, 06:01 PM
LepakVT's Avatar
100+ Head-Fi'er
Default
hey I'm looking around for my first budget portable amp
How does the PA2v2 compare with the Xenos 0HA-RHP? I'll most likely get one of these, unless there is a better alternative within the same price range.
  #762 (permalink)
Old 06-29-2007, 06:26 PM
Skylab's Avatar
Default
I've never heard a PA2v2, but based on comments I have seen, and my positive experience with the 0HA, I'd probably go with that, unless you can stretch your budget to the $149 mSeed Spirit.
__________________
Pics:
Head-fi feedback
  #763 (permalink)
Old 06-29-2007, 06:33 PM
Head-Fi'er
Default just got a T2
Out of the box - very obvious improvement in dynamic range, clear highs, deeper lows with iPod 4G, ALO Cryo Dock and various inexpensive cans ( SR-60, Senns 555, less so with Etys ER-4P). Can't compare with other amps (noob here) - this is my first. Waiting for expert's opinions on this tiny gadget. Cheers.
  #764 (permalink)
Old 06-29-2007, 06:38 PM
LepakVT's Avatar
100+ Head-Fi'er
Default
$149 is a bit too much of a stretch for me. The highest I'll probably be able to go is around $100. I think I may be going with the iBasso T2.
  #765 (permalink)
Old 06-29-2007, 07:07 PM
soloz2's Avatar
Send a message via AIM to soloz2
Default
I wasn't impressed with the pa2v2. it was too bassy for me.
__________________
feedback
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.3.2
Head-Fi.org
