Head-Fi's Sponsors
(Premier Sponsors bolded) |
Can Jam '09
(2009
International
Head-Fi Meet)
Impressions,
Reviews, Photos |
Can
Jam '09 graphic
courtesy of Edwood
Click on the links below
for Can Jam '09 photos,
impressions and reviews:
blubliss
1,
2,
3
dallan
1,
2,
3,
4
santacore
1,
2
nhat_thanh
1, 2
vpivinylspinner
1,
2,
3
amb
1
augustwest
1
eaglejo
1
johnsonad
1
shellylh
1
Jon L
1,
2,
3,
4
Germancub
1
zippy2001
1
IPodPJ
1
bhd812
1
Edwood
1,
2
abellaw
1,
2
minidiscs
1
atothex
1
HighLife
1
achristilaw
1
SiBurning
1,
2,
3,
4
SiBurning
5,
6,
7
LFF
1
Iron_Dreamer
1
doping panda
1
morphsci
1
ironbut
1
shaizada
1
jasper994
1,
2
jp11801
1
Uncle Erik
1
drubrew
1
(More impressions/photos
still being added.)
Head-Fi Blogs
and Facebook |
Head-Fi's Sponsors
| Portable Headphone Amps Discussion of portable headphone amps. |
01-03-2007, 04:18 AM
1000+ Head-Fi'er
Great review.
I'm surprised TH fans aren't up in arms about the Hornet M being higher ranked.
01-03-2007, 04:25 AM
500+ Head-Fi'er
Awesome work! Just adding on...sticky!
I'm considering the Headphonia for my DT990. I still haven't decided yet, as it's between this and a Portaphile V2^2 Maxxed, but your review doesn't make things easier...
300th post!
__________________
Upon us all, a little rain must fall...
In full use: Beyerdynamic DT990, Shure SE420, Koss KSC75
The rig: foobar 192-320 MP3/FLAC -> Silverstone EB01 -> Original Master -> v.2005 Beyer DT990/250
The portable: iPod Classic -> SE420
Feedback
01-03-2007, 04:39 AM
100+ Head-Fi'er
Skylab, we can guess what you did on your Christmas vacation.  Thanks for sharing, that'll be a "go-to" review for a while.
The only gotcha is that it really hard to get the amp gains well matched with an SPL meter. Different headphones will couple with the head differently, and its really hard to get repeatability acousticaly even with one headset (I have alot of experience in this area). Louder will sound better if all other attributes are pretty close.
What I do when running electronics comparisons is to match the amp gain directly. Cut a "reference" Cd with a few simple tones on it, then use a voltmeter to measure the amp voltage output into a resistor load (best to be equal to your headphones, if possible, so to best get equal levels if any amp has appreciable source resistance). A Neutrik terminated in the resistor will do the trick for a couple bucks.
If you want a really good (free) tone source to cut the CDs with, send me a PM.
x3 sticky it should be!
Skylab your hard work is obviously much appreciated by all (well all except Adrea maybe  ) who have taken the time to read it. Thanks a lot for putting it together.
__________________
Portable: Zune 120→JH-13 Pro
Home: HP TX2 Tablet→Pico Dac/Amp→JH-13 Pro
01-03-2007, 06:25 AM
Headphoneus Supremus: HeadFest '07 Lead Organizer The DOTU
Nicely done Skylab! Sticky it should be, yes (x4)!
01-03-2007, 08:58 AM
Head-Fi'er
Can someone answer this question. When it's said that an amp is noisy, what causes this, is it cheap componets, maybe cheap construction. I have a LDM2(low gain model) that I use with my ZVM (line out) and a pair of UM2's. I always thought this amp was pretty noisy, there's a lot of hiss (to the point where it can be heard even through fairly loud passages of music). I know that UM'2 are fairly sensitive which probably doesn't help. Would a better amp (say a hornet or a tomahawk) still have this hiss. Are they worth the extra money (this could be a silly question!).
Thanks in advance
01-03-2007, 12:21 PM
500+ Head-Fi'er
Yes,the two amps you mentioned will definetly reduce the hiss, or even eliminate it completly, depending on the listening volume. I can even get my HD650 to hiss with the Hornet, but just in high gain, and at volume level that would make your head explode. So at low gain, you should be perfectly fine.
So the quote "no hiss" from skylab should be read as "no hiss at sane volume levels".
@Skylab: Great review, and shurely a help for all who are in the market for a portable.
One note though: As you mentioned the noice when turning the pot for the Little Dot Micro, it should be mentioned, that this happens with the Hornet as well, due to the pot in use. Not that new buyers think their new toy is defect^^
__________________
"They that give up essential liberty to obtain a little temporary safety deserve neither liberty or safety." Ben Franklin, 1759
01-03-2007, 02:28 PM
Headphoneus Supremus: Reviewerus Prolificus
Thanks. I confess that I did not notice this on my Hornet. I will go back and check it and report back.
Also, I have added a few pics, and will add another later.
Also, DDF, w/r/t level-matching, I'm not sure I understand your point. I used a pink-noise track to match the levels of the amps, using the same headphones, to within 1db. Why wouldn't this work? Genuinely curious here. It seems that if all the amps were delivering exactly 80db at the headphones on the same pink noise track, then they're pretty well level matched...
__________________
PLEASE NOTE: Due to the volume of PM's I have been receiving in connection with my reviews, I no longer have the time to answer PM's from people with zero posts. Please read head-fi first before asking questions.
Team GO-U-NORTHWESTERN
Pics: Main Home Rig; Bedside Rig; Office Rig; Portable Rig;
Headphones: JVC HP-DX1000, HA-RX900; Headphile Deep Cup Darth Beyers VXD3,VXD4; Beyerdynamic DT990/600 (Manufaktur) DT770/600 (Manufaktur), DT880/600 Balanced (Manufaktur); HiFi-Man HE-2 Planar Magnetic; Sennheiser PXC-350; Shure SRH840
Home amps: Ray Samuels Audio Stealth (Mullard ECC32/CV4003); Decware Zen CSP-2 (Amperex BB 6DJ8/Sophia Princess 274B); Darkvoice 337 (GEC 6AS7G's/Tung-Sol mesh plate 6SJ7GTs); Wheatfield Audio HA-2 (Mullard ECC32/GEC 6AS7G/GEC U52); Ming-Da MC84-C 07 (Mullard CV4004/EL84/EM87); Audiotailor Jade (GEC 6AS7G/Sylvania 5751); J. Sound Lab Headphone (Mullard 12AT7); Audio-GD Phoenix; Musical Paradise MP-301 (Ken-Rad 6V6GT/Mullard 6AU6)
Portable Amps: Ray Samuels Audio P-51 Mustang; Decware ZenHead; Qables iQube
Sources: Denon DP59L table + Clearaudio Maestro Wood / VPI Scoutmaster + Benz Micro Wood L2 > Audio Electronics PH-1 DJH Phono Preamp; Music Hall 25.2 DAC; Denon DVD-5900;Red Wine Audio iMod iPod (Apple Lossless) & ALO VCap dock; Sony SCD-555ES SACD player
Loudspeaker system: Krell KAV250 Preamp>Sunfire Signature II Power amp > B&W Nautilus 800 Signatures + Velodyne FSR-1500/Martin Logan Descent
Tube testers: B&K Dyna-quick 650 & Dyna-Jet 606
Head-fi feedback
01-03-2007, 02:38 PM
100+ Head-Fi'er
Hopefully they're pics comparing the size of the Headphonia and Practical Devices X4. *nudge nudge, wink wink*
-The Grinman
__________________
Unabashed Utada Hikaru Fan
Portable: Zune 30 > xtrememac FS1
So empty now...
01-03-2007, 03:02 PM
__________________
Head-fi feedback
01-03-2007, 03:06 PM
Head-Fi'er
Thanks for the pictures.
Its great to compare the size of these and amazing how small some are compared to the battery.
01-03-2007, 03:35 PM
Smaller is better  Can't wait for my Tomahawk to arrive. Personally, I'd class the Hornet as just about the maximum size I'd be willing to carry outdoors
01-03-2007, 03:45 PM
100+ Head-Fi'er
w00t great review skylab.
__________________
[Headphones] → Ultrasone Ed 8, HD650 (Silver Dragon v2), SR225i, K701, HD595, SE530, ER-4S/P
[Amps] → RSA Apache, Headamp Pico Amp/Dac
[Sources]→ Macbook (iTunes), XP (Foobar 0.9.6.9), Lavry DA11 or Audio-gd DAC-9 MK3 (in bound).
My Head-Fi Feedback
My Ebay Feedback
1000+ Head-Fi'er
Interesting. Mine don't hiss at all.
01-03-2007, 04:29 PM
IMHO it should be noted that the Practical Devices XM4 has socketable OPamps. Its a dual OP amp design with one chip buffering the other (I think someone please correct me). I think its the only one in the review with this feature. Would it be possible to update your review with some commentary, on which amps have socketed OPamps and which do not?
What that means is the chips can be rolled for a custom sound that synnergizes with many different cans.
I wouldn't be surprised if it could rank higher on your preference list with a little OP amp rolling.
Thanks again for an excellent review, Mods cast my vote for a sticky.
__________________
Happy Listening!
The Kramer Tune of the Day
Stone Trek, My favorite Prog-Rock FM radio show
My Gear Profile
My Feedback Profile
The Grado Labs virtual tour
Headfest 2007 Videos
-Day1-
Six Degrees of Headfest
Texas Vibe
Takes My Breath Away
Freeborn Man
-Day2- Narrated by yours truly
Day2 Part1
Day2 Part2
In my CD Player:
Dreamtheater, Queen, Rush, Marillion, Iron Maiden, Deep Purple, Dio, Queensryche, Kings-X, Jethro', Yes, Primus, Eric Johnson, Liquid Tension Experiment, Junior Brown, Moody Blues, The Beatles, Styx, Asia
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
