Head-Fi: Covering Headphones, Earphones and Portable Audio
  #91 (permalink)
Old 12-30-2008, 07:06 AM
oogabooga's Avatar
100+ Head-Fi'er
Default
Originally Posted by GreatDane View Post
Since you have experience with HD600 and no buffers I'm curious about how much the buffer chips help...
Yeah... but I've only got a few hours experience with the HD600 :P, so I'm not entirely sure what they are capable of! Here's an example of what I have learned though - trying to play Massive Attack - Karmacoma leads to a "hollowed out bass" sound - the bass is there but not completely when using the XM5. Apogee Mini-Dac's HP out has more oomph.
I'll do my best to give some opinions when the BUF634s arrive. I also ordered a couple of different opamps to try out - if my stupid ears can tell the difference...
__________________
Home Rig: Macbook Pro (15", 160 GB X25-M SSD) --> Parasound 1500 --> DIY Mogami Neglex RCA --> SRM-313 (or H/K AVR 130 fed SRD-7/Pro) --> SR-404
Work Rig: Macbook Pro --> MisterX γ2 (USB) --> SRM-252II --> SR-202 Mobile Rig: [iPhone 3GS + Shure MPA-3C] --> Shure SE530
Everything I didn't like as much as the above is in my profile. Feedback.
If you haven't heard it, should you really be commenting about it?
  #92 (permalink)
Old 12-30-2008, 12:01 PM
swanlee's Avatar
100+ Head-Fi'er
Default
Or any of the buffer or opamp options needed for easily driven IEM's like the Atrio M5's?
  #93 (permalink)
Old 12-30-2008, 01:39 PM
GreatDane's Avatar
Send a message via Yahoo to GreatDane
Default
The Atrio spec is:
impedance 32 ohm
sensitivity 112 dB @ 30 Hz / 1 mW
I've never used the Atrio but they should perform very similar to my ER4P.
Buffers not needed. Whichever amp chips used would only change the sound signature. I've never thought that easily driven IEMs need an amp but it does often improve overall SQ, mainly opening up the soundstage from my experience.
  #94 (permalink)
Old 12-30-2008, 03:41 PM
swanlee's Avatar
100+ Head-Fi'er
Default
The Atrio spec is:
impedance 32 ohm
I'm already using a FIIO E5 with my Zune and Atrio's and I like the way an amp sounds especially with Bass boost turned on the E5. So I'm now looking for a higher quality amp and the XM5 has the options I want.
I'm definitely getting another amp i was just wondering if all this talk of buffer and opamps were really needed by normal IEM's
  #95 (permalink)
Old 12-30-2008, 03:49 PM
oogabooga's Avatar
100+ Head-Fi'er
Default
I asked Practical Devices the same question via e-mail - here's the response I got:
Originally Posted by Practical Devices
Your TripleFi's have a fairly low impedence; usually low-impedence 'phones benefit the most from chips with higher current capabilities (ie. BUF634 or AD8397), although only those with a fairly fine-tuned ear will appreciate the difference from your stock OPA134's.
As I'm getting my BUF634 chips today, I'll report back on the difference.
__________________
  #96 (permalink)
Old 12-30-2008, 09:37 PM
oogabooga's Avatar
100+ Head-Fi'er
Default
I placed two BUF634s in my XM5 and found improved bass with HD600s. Also, the volume knob is now about 3 "hours" back for the same sound level.
No change with the sibiliance/treble problems with TF10s. Still not sure what's up with that.
Also - tried some OPA637s. Didn't work wonderfully - with the 10dB swtich disengaged I got static - had to engage the switch to get music to play. This is to be expected though, as the 637s are known to need a gain of 5 to work, and the XM5's gain is a bit under 5 (until you hit the +10dB switch!). However, the 637-laden XM5 has static issues - touching the case or turning the pot gives staticy badness. I'm stubborn and am going to try again later today... for now I want to enjoy the music!
__________________
  #97 (permalink)
Old 12-31-2008, 09:26 PM
penguindude's Avatar
1000+ Head-Fi'er
Default
Hey all, my review of the XM5 is now up!
Here's the direct link: XM5 Review!
I found the DAC of the amp to be very competent, but it was still not as good as I'd like, especially driving the HD600. When coupling the XM5's amp with an external dac (emu 0404 usb), i heard some drastic improvement. So i think as a portable amp, the XM5 is very good, but driving phones like the HD600 i still prefer my heavy-weight tube amps!
PS Happy new years eve!
__________________
Check out my FEEDBACKS!
  #98 (permalink)
Old 12-31-2008, 10:01 PM
GreatDane's Avatar
Default
Happy New Year's Eve to you too.
Nicely written.
I still haven't compared my XM5 DAC to Pico DAC but I think I know what that outcome will be...
Even though having a DAC in the XM5 is nice, that is probably the feature that I'll use least...so just a bonus for me. My XM5 is meant to stay Velcroe'd to my 120 Classic.
I still haven't tested the XM5 with my HD650 but from what you've stated they should have good synergy.
  #99 (permalink)
Old 01-01-2009, 11:09 PM
swanlee's Avatar
100+ Head-Fi'er
Default
Nice review how did the Treble and bass boost effect the sound quality especially with both enabled? Any degradation or issues?
  #100 (permalink)
Old 01-01-2009, 11:30 PM
100+ Head-Fi'er
Default
You guys are killin' me here! Now I gotta plan for a new amp!
-HK sends
P.S. Anyone want to buy two PD XM4s? I need to finance an XM5.
  #101 (permalink)
Old 01-01-2009, 11:52 PM
1000+ Head-Fi'er
Default
Ah, forgot to mention those in my review! Like all equalizers, they tend to muffle the sound to a certain degree. But to my ears, both treble and bass boost are very good, giving a slight push towards both ends. It wasn't a night and day difference, but you can definitely tell either ends are emphasized.
__________________
  #102 (permalink)
Old 01-01-2009, 11:55 PM
100+ Head-Fi'er
Default
Would you say this would be a nice amp to accompany a laptop on trips for watching movies and listening to music?
-HK sends
  #103 (permalink)
Old 01-02-2009, 12:01 AM
1000+ Head-Fi'er
Default
-HK sends
There are many portable amps out there on the market. It all depends on your budget. But yes, the XM5 would be a great option.
__________________
  #104 (permalink)
oogabooga's Avatar
100+ Head-Fi'er
Default
I've found the bass boost to be a bit boomy, but MUCH better than the iTunes EQ. Treble boost is very good, on appropriate tracks.
HK_sends - The DAC is better than my laptop's, and with the BUF634 there is power to drive bigger cans (like my HD600s).
__________________
  #105 (permalink)
Old 01-02-2009, 12:05 AM
100+ Head-Fi'er
Default
Thanks for the replies.
I have used practical Devices amps before and while not being extremely high end, I like their sound, ruggedness and portability (and the whole customizing deal).
Never used a DAC before, but it does seem a decent place to start (and get a good amp in the process).
Cheers,
-HK sends
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Flickr/Twitter
Follow headfi on Twitter!
See Head-Fi photos on Flickr!
Head-Fi's Sponsors
(Premier Sponsors bolded)
Head-Fi Blogs
and Facebook
Check out Head-Fi's new
Blogs section.
Featured Head-Fi Blogs:
Jude's "Take My Word"
 From Japan - by Sasaki
Currawong's Blog
Start your own Blog!)
Attention
Facebook Users
Join the official
Head-Fi.org
Facebook Group
Flickr/Twitter
Head-Fi's Sponsors
Powered by vBulletin® Version 3.8.5
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.3.2
Head-Fi.org
